Results 1 to 11 of 11
Thread: Hall Effect Speedo Senders - Donor Cars
    Default Hall Effect Speedo Senders - Donor Cars
    Ok, im after a hall effect sender for a digital speedo. The aftermarket ones by Autometer and the like are bordering on the ridiculous, so i was going to hit up U Pull It to see if i can find one from a donor car.
    My current thoughts are
    • AE101 onwards Corollas
    • MX83 Cressida (post Update)
    • Later model Camrys(91+ i assume)
    Can anyone suggest any other cars. It would be going into a T50 which has the circular spindle with the tooth, rather than the square hole.
    Default Re: Hall Effect Speedo Senders - Donor Cars
    dont know how much help it is....but starlets have the speedo sensor in the cluster (ie the speedo is still cable drive, but it also generates the signal for the ECU)
    perhaps you could gut the bit u want out of something like that?
    Nah, after a remote adaptor. Ill take a picture of the one i have on my IPRA car later today. Its off some form of Toyota....
    Hm, thinking now, maybe it will have a part number on it....
    Altia ER34 GTT Domestic Engineer JetspeedCamry's Avatar
    Hey,
    This pic here shows the speedo sender from an E153 gearbox..1993 Camry.
    The drive assy is outlined in green, and the hall effect part (which has been unscrewed) is also outlined in green.
    Kind Regards,
    Kurt.
    1998 ER34 ニッサン スカイラインGT- T
    The sender on my auto JZX81 box was a screw-on adapter-type, I ended up screwing it onto the mechanical sender in my R154 when I did the engine swap. I'll see if I have saved any pics of it
    Here is the sender which is on my IPRA car:
    And also the part number for it:
    Im having issues getting my EPC online, anyone care to crossreference the number (for those of hard of eyesight its 83181-20040)?
    Sweet, thats an MX83 speedo sender according to the current EPC. It ranks in at about $400 from Toyota direct, but im sure it will be sourcable from a wreckers a bit cheaper
    Peewee bought a replacement one for UZZIO that only came in at a little over $100 brand new.
    Yeah, i reckon it could be cheaper again from a wreckers if its off an MX83.
    You can get the autometer ones for $130 or so.
    if its for an aftermarket electronic speedo there is heaps
    i have 5 diff ones here
    some toyotas have em
    4 pulse and 20 pulse
    nissan skyline pintara sort of model has em too they have 10 pulses
    they both have same thread pattern
    Junior Member Grease Monkey MacroP's Avatar
    Landcruiser 80 Series, all engines. Late model 78-79 Series 1HZ Cruiser utes/PC's.
    Celica ST182/5 Vintage.
    Cressida,Mark II, Chaser, Cresta, Post March 90.
    MX83 1UZ Conversion. UZZ31 engine, UCF10 Sump, UZS131 Tranny and engine fan idler. Custom exhaust and 147rwKWs.
  1. W5X Speedo Drive Comparision (Steel plate vs Alloy plate)
    Last Post: 12-08-2011, 07:58 PM
  2. you can light up your speedo with LEDS
    By puzzle man in forum Tech and Conversions
    Last Post: 21-03-2006, 10:34 AM
  3. Speedo and Odometer questions
    By Big T in forum Tech and Conversions
    Last Post: 04-12-2005, 05:43 PM
