Results 16 to 27 of 27
Thread: Stuck Flywheel bearing
    Default Re: Stuck Flywheel bearing
    OOps . Thought it was in the flywheel
    Jealousy is a curse
    Get a dremel with a cutting disc, cut a slit in the outer race.
    Once the cut is made, it will just fall out.
    As said you can buy little pullers, handy bastard of things
    Worth the money
    this thread might help - grease method works a treat, and I've used it successfully for exactly the same purpose after my brother hacked a bearing to bits...
    http://www.toymods.net/forums/showthread.php?t=5812
    Vanman
    tasmania
    the welding method is by far easier than buggerising around with a puller, and the puller arms will probly scratch the bearing seat.
    i don't reckon the grease method would work on something wit such a asmall surface area to seal on. it godamn messy too
    get a stick welder and you'll have it out in one minute flat.
    beer me!
    senior backyard mechanic Grease Monkey legend's Avatar
    welder works a treat
    Well the slide hammer worked, the one i brought was a $10 jobby from supacheap which didnt work to well so i got a long bolt and nut from bunnings and used that as the shaft for the hammer which worked better than the brought one. The end of the crank is a bit buggerised from the cresent spanner method but the mating surface is untouched.
    Gearbox is back in - Car is mobile again
    Time to revive the 28.
    yayayayay!
    shoulda bought a pulley! pulleys are fun
    so is jim beam wooohoooo!!!!!!!!!!!!!!!!!!!!
    Quote Originally Posted by love ke70
    yayayayay!
    Yeah buts what is more lasting fun?
    depends how often you drink...
    n when mummy and daddy are supplying a 4.5 ltr boottle
    Woohoo, wheres the funnel
    who needed a funnel, the bottle was in one of those swing things, and had a pourer
    hence why im only now awake....
  1. DIY: Transmission Rebuild *** No 56k ***
    By assassin10000 in forum Tech and Conversions
    Last Post: 30-05-2007, 12:07 AM
  2. C52 Gearbox and Spigot Bearing
    Last Post: 15-10-2006, 03:25 PM
  3. 4AGZE Flywheel
    By LiTTLe_DRaGoN_HuNTeR in forum Tech and Conversions
    Last Post: 22-08-2006, 08:17 PM
  4. 20V Conversion, need to find a flywheel HELP!
    By DeftAnesthetik in forum Tech and Conversions
    Last Post: 14-07-2006, 03:34 PM
  5. What flywheel is this?
    Last Post: 11-07-2006, 08:40 PM
