Is anyone able to confirm if I will be able to use the hilux calipers and peugot discs on stock RT142 struts and hubs? I dont have any atm so can messure it up myself.. Pretty keen to ditch my S13 setup for this one..
Thanks,
Chris.
Thanks guys,.
Thanks,
Chris.
Chris, pretty sure for 142 struts you use Nissan 4 pots.
Callum
Oh right.. Whats involved in the nissan brakes? Is there a previous thread about it so i dont clog this one..
Thanks,
Chris.
Just use the MX32's steering arm, as it has the same offset, as the RT132's/RA40's steering arm..Originally Posted by shelldrake
But camber..? also MX32's arm needs, a larger lower ball joint...![]()
i got to messuring the different angle's of the set's i have..
Angle between strut tube & disc/hub wheel face..
http://www.toymods.net/forums/showthread.php?t=29023
Project: '82, GA61 XX
Hey guys.
I’m looking at ordering some camber/caster plates for my 23. Are the S13 T3 plates a definite yes for fitment?
Can people put pics up o what they are running?
Cheers Mike
Mikie's Yellow Money Suck (formally known as Green POO RA23) now 3S powered
The New Toy JZX100
http://fourdoori.wordpress.com
Originally Posted by mikie
Mike, just order RA23 ones from Gabe at T3, as they do make them.
Cheers Chuck.
MS51Crown Coupe,
if i have the calipers with all the pistons the same size then do i need the 200sx/r33/r32 pads or the rx7 pads?
rx7 pads suit 2 pistons-different sizes calipers, so use the 200sx/r32/r33 pads![]()
Toyota Car Club (Qld)
thanks.
10char
does anyone know where i can get some more of these springs?
i only have 1 and need 4 right?
Cant remember the name but one of the 4WD stores on ebay sells them, send a few messages to the stores and ask around, its one of the bigger stores i think.
You need 1 per caliper
I have 2 per caliper![]()
You dont NEED them as such, they were put there from factory, they make it easier to hold the pads in place when sliding the caliper over the disc. You can get away without having them fine, I just used them on mine just cos i had them.![]()
