Page 65 of 68 FirstFirst ... 15556364656667 ... LastLast
Results 961 to 975 of 1006
  1. #961
    Feb 2012
    Wa
    Default Re: [Guide] Corona/Peugot/Hilux Conversion with Height Adjustable Coilovers [56k DIAF
    That hilux clip thingy you can get away with not using, mine only had one, didn't end up using it, no issues so far
  2. #962
    RA23 + 3SGE Beams Backyard Mechanic Major Clod's Avatar
    Thanks guys. Managed to get the clips from Toyota.
    For my caliper I checked Toyodiy and it confirmed the M shaped spring shown above. RX7 also uses similar springs.
    Seems to do the trick, no more rattles and clangs.
    Some callipers also use the sheet metal type Gold28 is talking about - depends on the caliper really.
    Thanks again for the advice!
  3. #963
    Nothing but a Backyard Mechanic caam's Avatar
    Apr 2010
    Hey guys just a quick question for those of you who have used coilovers
    Just wondering what height I should mount this sleeve?
    Not planning on slamming it to the ground but would like the rings somewhere near center of the sleeve -
    Using KWB-AGX shocks with the strut shortened 45mm.
    Ie high/low/middle?
    SR20DET TA23
  4. #964
    Feb 2012
    Wa
    I mounted mine to the spring perch area where the original spring was, seems to give good clearance and drive ability
  5. #965
    The way I did mine on the TA22 was put the weight of the front of the car on the springs and figure out what their compressed height is. I just dropped the crossmember on the springs and measured the compressed height with a ruler. Just be careful and chock the back wheels so the car won't move around whilst unsupported at the front. If you are using keeper springs then these will fully compress under load so you can just add up the keeper spring coil thicknesses then add to the main coil compressed height.
    Then you need to figure out where to put the lower platform. the way I did it was fit the strut to the car with wheel fitted but without spring. Support the front of the car with stands and jack the wheel up to the height you think you want. Measure the compressed spring height down from the top spring perch and mark on the strut.
    Remember there is a stack up of the lower perch and the two nuts so the threaded tube will need to be centred a bit lower than where you measured it.
    Best of luck and take care when measuring the spring compressed height.
  6. #966
    2sc Breaker!!!! Backyard Mechanic bmxer54's Avatar
    Finally got to the end of this... Did the brake conversion on my rt104, worked like a charm (I'd like to suggest a die grinder and 6.25mm burr, had the holes in the rotors elongated in under 5 minutes)
    For anyone asking about st141 struts with the pug conversion: It will not work the bolt spacing on the xT14x struts is 100mm and the hilux caliper is 90mm not to mention the xT13x caliper mount holes ate threaded - use the R33/BA brake upgrade
    When using cusco camber plates with coilovers and t3 needle bearing spring perches as i did in my ke30 you will need a spacer to sit between the spring perch and camber top. I used washers initially to get the sizing right and then got a piar of these made
    Peter
    My Rides:
    1x Brown St141 corona csx. powered by a gen 2 3sge, 1x RT142 turbo 1UZ, cd009 and G series, 1x Gj Sigma Scorpion injected and turbo'd, 1x KE30 2TG, w58 and F truetrac, 1x RT104 18RG, w58 and F truetrac
  7. #967
    highly underrated Backyard Mechanic
    Feb 2010
    how'd you go getting the rotors on? the hilux calipers bolt right on if the current calipers are the twin piston sumitomo's.
    Im thinking ill get ms65 hubs apparently they will fit.
    RT104 with 4AGTE
    Some assembly required
  8. #968
    Rotors bolted on sweet with the mentioned elongating of holes.
    If your gonna use the crown hubs the rotors need to be redrilled to 5x100 They definately will fit though, my rotors were on ms65 hubs but using them on the other car with the BA/R33 combo
    and of course the O.D. machined down a little on the pug rotors and some very minor dust shield mods but then it will all just bolt together
    if you want some pics pm me your email and ill send them over
    Peter
    My Rides:
  9. #969
    Feb 2010
    I did some research and the ms65 hubs can be used with the hilux calipers just need ford transit rotors which are cheap and plentiful (150 for a slotted and dimpled set delivered)
    the hubs themselves seem to be a challenge.
    on another note does anyone know where I can get ultrasonic cleaning fluid? I slavaged an old ultrasonic bath from the local vet and it works perfectly just don't have the cleaning solution otherwise id be getting my calipers cleaned.
    RT104 with 4AGTE
  10. #970
    The old One Backyard Mechanic
    Quote Originally Posted by bmxer54 View Post
    Peter
    MS65 hubs are 5X114.3 not 5X100
  11. #971
    Feb 2010
    RT104 with 4AGTE
  12. #972
    New Zealand
    Quote Originally Posted by ddeane View Post
    Depends if the rotors are being bolted to the rear or being slipped over the front.
    Callum
  13. #973
    Feb 2010
    here's another one I dug up using jzs133 rotors
    http://www.toymods.org.au/forums/tec...ona-wip-4.html
    but pretty useless without the hubs.
    RT104 with 4AGTE
  14. #974
    Feb 2011
    Townsville QLD
    My Coilovers with Hopper Stopper brakes 5X120 hubs http://www.toymods.org.au/forums/for...back-18rg.html
    2001 TOYOTA HILUX KZN165 DUAL CAB TURBO DIESEL
    1999 SUZUKI SV650 , fuel of choice AVGAS
    1981 TOYOTA CELICA RA40 LIFTBACK 18RG - AVGAS ALSO
    don't adapt and overcome do it correct the first time
  15. #975
    I am about to do this, what is the recommended height to weld the sleave on with SW20 shocks?
    Thanks in advance
    Nath
    -Just Alloy Radiators-
    www.alloyradiators.com.au
