I had two new lines made up as I needed them slightly longer, I also figured it was a good idea to replace 30+ yr old lines as they didn't look the best.
I'm using the caliper with two different piston sizes, it had the same fitting as the RA23 Caliper (standard flared fitting). I just took in my old brake lines and said I need new ones, but each 2 inches longer.
Make sure you measure before you get them made however, just to be sure!
