Results 1 to 11 of 11
Thread: 4agze igniter wiring!
    Junior Member Grease Monkey bassy's Avatar
    Exclamation 4agze igniter wiring!
    hey all, ive been searching for weeks and this is my last resort, but im after a wiring diagram for an ae92 4agze that has twin coils. Specifically the igntiers wiring diagram.
    Any helf would be much appreciated + rep (obviously)
    thanks, bassy
    Junior Member Grease Monkey craigy's Avatar
    Default Re: 4agze igniter wiring!
    Are you using standard or aftermarket management?
    4AGZE powered AE86
    SR5 dual cab Hilux
    265 powered VJ Valiant Charger
    sorry, yeah it is standard
    My Missus is a Domestic Engineer BradW's Avatar
    Hey bassy, have you seen the 4agze diagram in the tech docs on the old forum? It shows the wiring between the ECU and ignitor but not between the ignitor and coils.
    Link to down load the diagram is here. It's a zip file so you need to download and open it.
    Hope it helps.
    Brad
    Old Corollas never die...
    My KE30
    yes i have that diagram, my ignter has two plugs, 4 in one and two in the other. two wires ARE connected to the ecu but there is still 4 left over, is one plug for the taco or other output? and yeah i need wiring diagram from the coil to ignter.
    If anyone has a 4agze some quick pics would be great. ive seen 4age ones but they are so different.
    thanks people + rep
    Bassy
    The four left over would be
    Ignition supply
    Tacho or IG- ? (although I think the tacho output is from the ecu)
    Output for coil 1
    Output for coil 2
    Coils also have ignition supply to them.
    This is by no means 100% correct, just an educated guess. Someone else will be able to confirm.
    Brad
    My KE30
    that makes a lot of sense Brad. now i just need the clours of the wires
    cheers, bassy
    Bump! want this running by the weekend people!
    bassy
    Code:
    Igniter	B     IGT
    Igniter	B-O     IGD
    Igniter B-Y     IGF
    More colours and pinouts here:
    http://www.club4ag.com/faq%20and%20t...GZE%20AE92.htm
    and here
    http://www.club4ag.com/faq%20and%20t...Comparison.htm
    thanks takai, but i already know those ones, they are also shown in the diagram bradw posted. its the others im more concerned about, those that connect to the coils...
    the computer side of wiring im sorted, the coils are never shown in any of the diagrams. If anyone knows if another engine uses a similar setup us the twin coil pack 4agze then i might be able to figure it out from there...
    thanks, bassy
    Victoria, Mt Macedon
    Two coils. Each has two wires going to it.
    Coil 1 (1 and 4) - Ignition 12V and IGT
    Coil 2 (2 and 3) - Igntion 12V and IGD
    Though I may have IGT and IGD swapped, I can't remember off the top of my head.
  1. AE101 4AGZE wiring diagram Needed
    Last Post: 28-04-2006, 12:29 PM
  2. understanding 4agze wiring diagram-HELP-
    By slide86 in forum Tech and Conversions
    Last Post: 18-04-2006, 06:09 PM
