Results 1 to 9 of 9
Thread: Oxygen Sensor
    New South Wales
    Default Oxygen Sensor
    My car thinks either oxygen sensor or the wiring to oxygen sensor is not working properly. Is there any way to discover which it is - wiring or sensor? and also is it too bad to leave it temperarely if i need to replace it or get in there RIGHT NOW and do it. car seems to be running fine.
    btw its a st162 - 3sge
    thanks
    Default Re: Oxygen Sensor
    my 4AGE has never run an oxy sensor (bought a new one, screwed it in but havent wired it up)
    the only real reason you need one is to stop the exhaust leak, it will run quite safely without it hooked up, you will just get marginally worse fuel economy on the highway.
    www.vicdrift.com
    now targeting: targets
    formerly shinybluesteel
    ST185 GrpA #135 Automotive Encyclopaedia Toobs's Avatar
    Actually you'll get much better economy with a good working o2 sensor connected.
    The pimpmobile sans oxy sensor used to suck about 12 ltrs per 100km's and then about 8ltrs per 100km's once we connected the oxy sensor back.
    If the wiring is stuffed then I assume you wouldn't get a reading between OX and GND on the diagnostic connector... if the sensor is a bit stuffed then you will get a reading, it just won't refresh very often.
    Check the BGB in Lances signature for proper test procedures.
    Note: The ST185 engine manual has the 5SFE, 3SGE and 3SGTE engine information,
    Quote Originally Posted by shinybluesteel
    Toobs i think hes saying that without it you get worse fuel economy on highways.
    Main reason for having them is so on highway driving your computer can lean right out an return better economy.
    - LeeRoy
    I know... I was saying that what he says is incorrect... without an oxy sensor economy will be much more than marginally worse and will be worse at all road speeds.
    hey i was right, i said marginally and it is marginal. seems it is a big margin though and not a small margin
    all i was trying to say is that it is in no way unsafe to not have an oxy senso hooked up. really should hook mine up one day, but headers are going on soon and i don't want to hook it up on them much.
    www.vicdrift.com
    oxygen sensor is good.
    why waste fuel if you don't need to?
    as for original question, unhook the O2 sensor (how many wires? just one?) and connect multimeter between the signal wire at the O2, and the O2 pin on the loom where it plugs into the ECU...
    to check sensor, connect multimeter between O2 pin at ECU,(positive) and put negative to ground, and set multi so it can read 0-1V... if, when you are cruising, the voltage doesn't go up and down, then maybe there is prb with O2 sensor
    A real nowhere man Backyard Mechanic 88FOUR's Avatar
    I have recently snaped mine by mistake....was hoping they are cheep to replace...?......If I wanted to spend heaps on petrol, .I would have brought the torana I was looking at when I decided on the gt four.
  1. ECU jzx100 pins
    By splatt in forum Tech and Conversions
    Last Post: 30-08-2011, 07:11 PM
  2. 1JZGTE With Microtech LTX-12...what air temp sensor?
    Last Post: 16-02-2006, 11:38 AM
  3. MAP Sensor line placement
    Last Post: 24-01-2006, 06:27 PM
  4. O2 sensor mz20 7mgte
    By Steve-AE86 in forum Tech and Conversions
    Last Post: 19-01-2006, 12:10 PM
  5. o2 sensor heaters
    Last Post: 17-01-2006, 07:16 AM
