Results 16 to 24 of 24
Thread: Water injection vs Intercooler
    I have a pet Backyard Mechanic Gibbon's Avatar
    Aug 2006
    Default Re: Water injection vs Intercooler
    This also sounds good. And have it triggered at a certain boost level...
    Quote Originally Posted by Toysrme
    Run an intercooler, run water injection & install a very small nozzle to hit the outside of the intercooler also.
    wget -r http://www.toymods.net | grep -i "1jz MA61"
    1 Result found:
    Gibbons MA61 + 1JZ
    Alabama
    Cool Re: Water injection vs Intercooler
    Would advise against running water injection upstream of a turbocharger, the vanes are easily damaged if getting hit by water droplets.
    Actually that's untrue. Ask Garrett. Even their head Australian (Geoff Watson) @ your turbo center has been quoted to saying it's not the fluids hitting the blades that cause a problem. It's people not properly filtering the airflow. What you can get into is poorer end atomization that might be achived post compressor.
    I have thought about this in the past also.
    I already have a FMIC but was going to add water injection to cool the intake charge.
    When looking at the price of the kits I figured may as well just spend the $$ and get a nitrous kit instead. Cools the intake charge and makes more power.
    From what I have found, the cylinder temps dropped with water/meth injection but it wouldn't actually make more power. So for people who have to run crap fuel then it would be a good idea but if you can run good fuel just do that get an air to air or w2a cooler and give it a shot of n2o when you want to blow your turbines into the cat
    QUICKEST 1JZ'S IN OZ
    But for people who dont/cant run a intercooler water injection is a viable option. Ther are other positives in not running a intercooler such as shorter inlet path.
    (\__/)
    he is gaining support
    OK WW2 radial engines, fitted to aircraft, used water methanol injection.
    The water meth, was injected after the first of 2 centrifugal compressors. This was used to increase air density, so the pilot who controlled the fuel air mixture, could add more fuel. More dense air + more fuel = more torque, enabling the big lumbering buses to get off the ground.
    What happens to a jet engines compressor leading edge, when it flies through rain, erosion/no erosion.?
    Best bet is to ensure very good atomisation of the water, before it is injested anywhere in the engine.
    cheers Chuck
    MS51Crown Coupe,
    Have a talk to Mark Alford from http://www.full-throttle.com.au/ about running water injection and intercooler/no intercooler. SInce he has done both, he has real world data from his datsun sunny IPRA car with a turbo FJ in it and will be able to advise you on what to do.
    Dave
    get a jjr intercooler from justjap in syd www.justjap.com get the 450x300x76 these a dirt cheap (even cheaper on ebay sometimes) and it will fit behind the grill where no one can see it:
    post is here for many different options:
    http://www.toymods.net/forums/showth...23+intercooler
    im going with the fmic mentioned above and buying a water sprayer kit that will pulse water over the intercooler when at a certain temp
    Jaycar:
    Intercooler Water Spray Controller ==> Cat. HB-6013
    Im even thinking about placing one inside the intake before the intercooler.
    Also, DONT do what I read some dumbass do in a recent hot4s mag and stream a jet of water directly into the turbine wheel, cos at the speed its trvelling it actually cuts through it!
    Goodluck!
    Craig
    Quote Originally Posted by SillyCarS
    Jaycar:
    You mean KC5374 + KC5422... HB6013 is a jiffy box.
    lol!
    yeah i put down the part no. to the box they recommend to put it in
    thanks
    craig
  1. Cooling Systems - Overheating Problems.
  2. required jet and boost pressure switch for water injection?
    By -=DV=- in forum Tech and Conversions
    Last Post: 30-03-2006, 10:53 AM
