Hey Southo,
Mine got down to 4 degrees in the centre vent but that was with everything open with fresh air - no doubt with recirc and doors closed it would've gone lower. Keep in mind -3 will freeze water, so your evaporator will freeze up if it's getting that low....
The front condenser fan (together with the tiny 6" fan) in the MX83 is designed to only come on when the pressures in the A/C have gone up above normal levels (but not critical). These fans "help" the clutch fan in drawing air through both the radiator and condensor.
By no stretch of the imagination are these to be construed as the *ONLY* fans for the condensor - they are a failsafe - a fully operational clutch fan suffices for both the radiator and condensor, with the 10" generally never being activated.
Regarding your second question, the answer is absolutely
Remove the 10" fan (it does nothing useful) and run the 14s when A/C is activated. This will draw air through the entire surface of the condensor.
Toyota sets it up so the two fans run in series when the A/C is activated (low speed) and then they kick over to parallel operation (high speed) when either the refrigerant pressure goes up or the coolant temp goes up. (This has been covered in another thread before).
I set it up like that in the AE86 but it's a lot easier just to make them come on with the A/C...
Mos.
