Originally Posted by
The Witzl
Dissy cap is the same as an 18R-C, get them from supercheap, same as rotor button.
18R-G oil pump is higher volume than 18R-C; the impeller gears are about 5mm taller thus flow a fair bit more oil. They are straight swap replacements for each other in the engine block tho.
18R-C water pump is ok to use, they are the same. There are 2 or 3 different types tho, get the one that matches your engine setup - they differ by fan type and pulley type.
Dont know difference between 18R and 18RG oil filter mounts, but I have found the oil filter mounts on my 18RG's do take the stock toyota filter with the EFI manifold. You just have to put it on at the right angle, and for heavens sake dont use a fucking Valvoline or equally poo filter - TOYOTA ONLY!!
You can use a 2JZ oil filter on the 18RG oil filter mount - i have done this before. It's a bit shorter.
Thermostat i dunno if different to 18R.
