Page 3 of 3 FirstFirst 123
Results 31 to 32 of 32
Thread: 20V cam gear differences?
    New Zealand
    Default Re: 20V cam gear differences?
    yes iv been doing this job for around 4 years now and i agree with you
    IME only the 1kz and blacktop ones have failed. usually on the 2nd belt. and iv had 2 cases of the black top ones failing after being replaced.
    on the waterpumps.... thats quite common on the 3sfe after the customer doesnt want to pay for a pump and cambelt time....
    so, in general toyota tensioners are good. and with the 2 mentioned above, they should be replaced everytime you do a belt. do that, and i doubt you'll have an issue
    please note that when i said above it will fail, i was talking about the topic specific 20v (BT) one
    please, no more PMs!
    Feb 2007
    Timaru
    I have done this and know all the in's and out as I searched thru it all when converting my race engine to blacktop head.
    All pulley have the same diameter and number of teeth.
    The crank pulley is the same between the Silvertop and Blacktop.
    The only difference in the VVT pulley's is that the BT one is 5 dge more advanced than a ST one. The only difference is the location of the locating pin indentation on thye inside. They both move the same amount on VVT activation.
    The EXH wheels, The BT has 3 spokes and the ST has 5.
    Both the same Diameter and number of teeth.
    So you can take a set of Blacktop cams and camwheels and put them straight into a silvertop engine no problems.
    The belts are slightly different lengths,and the only reason for that is the amount of travel the mechanical tensioner has compared to the hydraulic one.
    There could be a slight difference in the widths of the belt's/pulley's,
    but they are so close it's not worth worrying about.
    - KE70 Corolla Dx -
    - 500hp+ 7AGTE 20V turbo -
    - MRS/Hayabusa turbo **sold**
  1. 4AGE 100kW Dizzy Oil Leak Guide
    By Talasas in forum Tech and Conversions
    Last Post: 05-11-2014, 09:00 PM
  2. Classic celica suspension TA23
    By WindeX in forum Tech and Conversions
    Last Post: 12-01-2007, 09:54 PM
  3. Replies: 0
    Last Post: 30-08-2005, 09:43 AM
