i'd take 3 sets
I'd take a set
Cam
SR20DET TA23
i'd take 3 sets
SHEPPO..
i boughted some DBA slotted an drilled rotors... and then re-drilled them.
i will get the angries if i cannot get the engineeeeeering.
mine passed engineering as it was
You can put me down for 2 sets of the blanked rotors also, as Ive just bought Stews busted volvo diff. :-)
Does anyone happen to have any 4x114.3 stud volvo axles they would be interested in selling?
Im also after a 3.9:1 to 4.1:1 crown wheel and pinion to suit also.
Let me know asap before I go re-stud another set.
Cheers Josh
I will definitely take 2 sets of blank rotors as the guy machining my axles doesn't like the idea of drilling my existing disks!
Hope this goes ahead.
Cheers Richard
Elfin Clubman + 4agze + microtech
RA28 Celica + 1ggte + mines
Subaru WRX + EJ20 + ecutec
Not sure whether this is a red herring but I arranged with Brake Works in Queanbeyan (trevor hicks) last year to organise some undrilled rotors from DBA (which I did get) for my conversion. They did cost a little more, I think about $200, were slotted, and took less than the 12 weeks quoted to arrive.
Craig
I'll be in for 2 sets of blank disks. Any update on these?
Eddie.
4agte finally completed. 234rwkw @ 8125rpm. Tis fun
Put me down for two sets if the group buy is still going ahead.
Andy.
Group buy at this stage does not look like a goer as there is not enough interested parties at this stage. If everyone who expressed interest is still keen then about 16 sets would be accounted for which leaves 34 sets to meet the minimum order quantity.
I have been thinking of a way around this and the best i can come up with is to use a different disc which either has the right stud pattern to begin with, or lends itself to drilling easily.
I have also noticed how farkin heavy the volvo 2 pot calipers are (cast iron!) and the fact they use a "Bubble Flare" on the brake line makes them different to the rest of the car's "Double Flare" lines. So this said i think i am going down the path of finding a brake disc and caliper i can adapt to save weight, use normal brake line flares, and source discs.
At this stage i will use the volvo stuff to get the car going, but i feel there's plenty of room for improvement!
SHEPPO..
further more, whilst researching the idea of brake upgrades i stumbled accross this idea:
They have used the middle section of a 240 rear disc and cut away the outter section leaving only the handbrake drum. This was slipped "under" the new disc to retain the volvo drum handbrake function.
Obviously this will space the new disc away from the caliper somewhat, but when you're making a fully custom set of rear brakes it's nothing that can't be solved with a caliper spacer/adapter plate.
SHEPPO..
The stock Volvo handbrake isn't that flash to start with as it is self energising. You will get that first bit of slop before the brake bites in. If you are going to the effort of new calipers I would consider your options with complete brake swap for disk and handbrake setup
