Hey all,
just got a pm askin for some additional info, so i though i would post it up here as well...
Questions "Good write up dude, that has got to be the cheapest diff conversion i have seen just becuse there is no need to mod the tailshaft and shorten diff. Just curious how did you go about making the brake lines mate up and did you run into any clearance issues with the rear shocks and caliper as i did one time on a borg warner conversion, how did you hook up the handbrake cables, and does the drive shaft just bolt straight up (holes line up ect), and did you just weld the diff or is there aftermarket spools ect available. Would appreciate your help"
yeah, it is cheap and works well.
was suggested as an option by my engineer who have a 350 chev in his volvo, so i started talkin to a few guys who race volvos (circuit, hillclimb and rally) and none of em have ever had a prob, even with tough v8s etc...
as for the brake lines, i used the original celica ones, they fitted into the volvo calipers, just a slight adjustment of the ends of the lines...
the tail shaft holes are out slightly.... so i redrilled the holes (90 degrees around) in the snout of the diff.
no shock issues or springs for that matter.
as for handbrake, i dont remember exactly... but it wasnt real hard...... if you had one ready to go i could get under it and take a pic. my digi cam is out of action at the moment though.
i did use the volvo cable, clamped it into the celica positions under car, and attached it somehow to the lever....
i have a single piece tailshaft fron an early celica, and the diff dit the floor when first fitted, no idea why, cause i had the single tail shaft in with the stocker. Steve had the same problem with his when he did the hilux diff..... adjustable upper control arms fixed the prob.
i just welded the centre. we did look for spools, not real hard. they are available for dana diffs (like dana 44's) but we didnt find a listing for the dana 30. we didnt call round though. i needed it looked in a hurry, and centres are worth nuthin so we welded it.
Stew
