Results 16 to 26 of 26
Thread: Getting new cams. Do I need new springs? 1JZ
    Junior Member Backyard Mechanic 1jzracing's Avatar
    Default Re: Getting new cams. Do I need new springs? 1JZ
    you wont need springs!!!
    people seem to think springs make a big difference but untill you get valve float from big rpm or massive boost blowing open the valves then you wont need to make any changes to the springs
    a higher lift cam compresses the spring further obviously so the spring has a much higher rate at full lift than it would with the std cam and the std lift cam is good for 7500rpm at 23psi so a high lift cam will be good for more!
    i have made over 350rwkw with std springs and a combo of 265 and 272 cams i spin 7800 sometimes with boost of 24psi or so, if i want to run more rpm then i think springs will be changed
    on a side note i have changed springs without removing the head on another 1j and it was real tricky but can be done no problem
    i agree with 1jzracing on this.
    i know of a few cars running 264 cams or 264 272 combo with factory springs running into 30 psi of boost without a problem
    matt at magic is a prime example.
    8.3 et PB 169 MPH PB
    Not stressed about duration or the amount of PSI affect on springs, its purly the lift that worries me. Going nearly an extra 2mm lift is a fair wack of difference. I wanna make sure that its not going to Fk with the shape and rebound retention.
    1JRacing I'm actualy waiting on the guy you recommended a while back to get back to me with some recommendations. Prolly going to get him to grind me up a few sticks.
    Malicious
    Oh also thinking of reving it out too 8000rpm, depending on how the power curve looks. Will this still be ok on the standard springs with the high lift cams?
    Malicious
    my rev cut it set at 8000 on factory cams and springs.
    i usually change at 7500 on the shift light. i havent seen any issues thus far.
    Quote Originally Posted by ReQuieM
    Hope so because that is what I was planning on doing albeit with baby US 2jz cams
    QUICKEST 1JZ'S IN OZ
    Wgtn
    What about 8000rpm, 264/272's on the stock valve gear??
    Is there a problem with shims coming adrift at higher lifts/RPM?? Retainers also??
    very rare for retainers to come out, maybe shimless buckets might be a good idea for that type of specs
    The boobs are back
    I know it is hearsay but people in the US are apparently revving to 9000rpm with the Crower 264 (272 small core) and stock springs and retainers.
    BTW did you get lost? Haven't seen you around for a while
    just got word from Adrian at franklan cams in NZ and he FINALLY!!!!! has some more blank billets so should be able to supply cams again pretty soon
    a fool remains undescovered untill he speaks!
    Yeah I haven't heard from him since I started this thread. I was going to buy them through him then he disappeared... might have to save up and get a set now.
    Malicious
  1. Fitting US jza80 2jz-gte cams into 1jz-gte
    Last Post: 01-10-2024, 03:46 PM
  2. [warning] TRD 272degree cams for 4age
    By progkamol in forum Tech and Conversions
    Last Post: 19-07-2006, 09:48 AM
  3. 1jz vs 2jz heads
