Page 3 of 3 FirstFirst 123
Results 31 to 34 of 34
Thread: Inside the 1FZ......
    Junior Member 1st year Apprentice Cplus's Avatar
    London
    Default Re: Inside the 1FZ......
    Quote Originally Posted by MS-75
    Should be an easy run into the dyno session-no late-nighters required for once.
    **cough** Bullshit **cough**
    I'll ask Alex - he'll tell me the truth.
    Have you helped him to start fitting his goodies yet?
    The 1fz is mated to the 7M-A340 bellhousing using a hand-made 8mm thick steel sandwich plate.
    The difficulty was that the 1FZ bellhousing pattern had a diameter 100mm larger than the A-340 bellhousing, and also waaay to big to fit in the crown's trans tunnel. (which was designed for an M-series drive-train obviously)
    Basically the sandwich plate is a big steel ring which is bolted to the engine, and locates on the existing dowels on the 1FZ. The A340 then locates on dowels in the sandwich plate and bolts up to the sandwich plate.
    Obviously, during the fabrication I had to ensure that I got the centre-lines of the trans and motor lined up perfectly. To be honest, the fact it worked still amazes me.
    Thanks for the info. Can I ask what torque converter you used and with the 8mm adapter plate was the input shaft length and splines OK etc.
    HHeLiBeBCNOFNeNaMgAlSiPS Backyard Mechanic
    Hey Caelum. That's rude. Both the straps and the glue were of semi-decent quality.
    Sorry mate, I didn't mean to denigrate the straps and glue.
    BTW do you have any external dimensions for the 1fz (besides bloody tall?). I guess a lot of people are going to be interested in them after this thread and the supercrown progress, but it might help to show that the 1fz will only fit in very few cars.
    you know what I mean this electric stream
    and my tears in league with the
    wires and energy and my machine
    this is my beautiful dream
    London
    is it this one or the previous incarnation that ran the Pajero stallie?
  1. Solvent resistant paints (for inside fuel tank)
    Last Post: 02-10-2006, 07:49 PM
  2. 1GGTE metalic sound pinging inside engine !
    By romelan in forum Tech and Conversions
    Last Post: 27-06-2006, 02:23 AM
  3. replacing the inside window trim on an RA40
    Last Post: 13-01-2006, 09:27 PM
