Results 1 to 8 of 8
Thread: ga70 auto stall speed
    vic
    Default ga70 auto stall speed
    Im wondering does anybody know or can check the auto stall speed of a ga70 .
    check it drive not reverse.
    Iwant to use the convertor in a cressida with 7m and dont want to use the 1g one if the stall speed is higher than the 7m one.
    thanks guys
    Dave
    Default Re: ga70 auto stall speed
    The stall speed is dependent on the amount of torque the engine produces. So if you had the 1g converter and it stalled to 2200rpm and you put it in a 7m it would most likely stall at 2500rpm or so (just guessing numbers)
    Do you have a 7m-gte? If the 1g and the 7m stall at the same rpm with their original converters then if you put the 1g one in (if it fits) then I think that would be a good thing. I just went from a 2000rpm to a 2500rpm stall and I noticed absolutely no difference in drivability.
    QUICKEST 1JZ'S IN OZ
    1G beliver Backyard Mechanic BLK1g-gte's Avatar
    Hey when u stall the car up...do you just do i tagainst the brakes ro do you use the handbrake....just curious what the best method to use my mv 2800 stall for the best launch....
    Junior Member Backyard Mechanic V-Na's Avatar
    Footbrake, I don't know why you'd use the handbrake.
    vic
    well ill give it a go and see what it is , most are around 2200 rpm
    Dave
    most use foot and handbrake. Any additional braking force is good as you will be able to rev it a bit higher before it starts spinning.
    Quote Originally Posted by cambelt1
    Dave
    My response was directed at the post above it.
    You might need a bit more braking force to find the actual stall speed of your converters. Although you could probably perform a valid comparative test between them with conventional brakes.
    To find out what the stall speed is:
    1. drive along at about 15kms/hr in 1st
    2. mash throttle
    3. watch what the revs "flash" to before the car starts accelerating
    That is your stall point. This is the figure that the converter shops will give you ie.depending on the engine a 2800rpm converter may actually go to 3000rpm on the foot brake.
  1. jzz30/A340E speed sensor issue
    By lumpy in forum Tech and Conversions
    Last Post: 20-01-2006, 12:28 PM
  2. KE 35 conversion from 2 to 3 speed (auto)
    By woody012 in forum Tech and Conversions
    Last Post: 02-01-2006, 10:12 PM
