Results 31 to 45 of 51
Thread: Quality of Catco Cats?
    Oberst Koi-Master Backyard Mechanic
    Default Re: Quality of Catco Cats?
    Metalcat? Importbitz (forum sponsor) carries them.
    As for the fittings, how would you guys make them?
    A threaded fitting, then drill out a hole in a shortened bolt, weld a small piece of pipe to the hollowed-bolt for attachement to a pressure gauge?
    "Welcome the dude who ain't the buyer of mugs"
    would be good to have a bit of a longer pipe possible.. to cut down a bit on heat.
    silicon is good for maybe 400deg, but no higher.
    a short bit of pipe, with a small flange on it.. and then bolting on another section with an insulating gasket, might healp to cut down on heat transfer up the pipe.
    Can you fit twin 2.5" or 2.25" cats?
    Ghetto Goodness Automotive Encyclopaedia Ghetto-AW11's Avatar
    ie re do the exhaust into a twin system? I suppose i could, but the thing is it now follows the stock path and gives maximum ground clearance which is what i want.
    Homebrew, triumph triple, turbo aw11
    Not so much a whole twin system, just twin cats.
    Yeah i suppose thats possible. I have got to think weather i go another catco 3 inch and run them in parralell or just one big metal cat.
    Aug 2006
    Try one of catco's metal cats. They seem to flow really well, lets the 1jz hit boost cut with more than 75% throttle....
    I have their 3.5 inch jobbie and its "sposed" to flow up in the 800cfm range, thats more than 200cfm better than metal and magic cats flowrates.
    Yes they are pricey but i think they are worth it and as i said before they are quite small and would fit the aw11 nicely
    http://www.catco.com.au/
  8. #38
    Something like that officer Doofy? I picked it up tonight.
  9. #39
    Aug 2006
    Yep thats the one, look forward to hearing what you think of them.
    Any chance you can get it back on a dyno and compare it to your without cat results.?
  10. #40
    It will be going back on the dyno, and tuned to suit. Yay for bending over and getting dicked for the sake of power !
  11. #41
    Aug 2006
    lol really, can i ask what $$$ you picked it up for?
  12. #42
    Ballpark 300-600$
  13. #43
    Penrith BC
    ../delete/ban
    tech moderator
  14. #44
    Aug 2006
    So Ghetto did you ever get the cat installed? And any results from the second dyno run?
  15. #45
    Yeah, it was an improvement, 14rwkw over the standard catco cat. But 15kw down on running no cat at all.
  1. Two cats in series
    By kugzs in forum Tech and Conversions
    Last Post: 10-08-2006, 08:32 PM
