you will need to put it in the oil line going to the cooler, so the alloy adapter on the block and tap it on the line that going to cooler in there the oil pressure will be higher and more accurate as well ,just a side note the altezza 3sge have theres in the sump right next to the filter
also the altezza oil pump is higher in volume my pressure is in metric so on idle sits on 200 to 300 and at full load sits up to 650 to 700 depending on the days temperature as well ,and im not using a cooler std water to oil heat exchanger from factory
