Results 16 to 19 of 19
Thread: Vacuum Diagram for 2tgeu?
    New Zealand
    Default Re: Vacuum Diagram for 2tgeu?
    Got home a little late last night, will try for pics tonight or tomorrow morning.
    Callum
    Obama Family Friendly Backyard Mechanic 74sLeeka's Avatar
    May 2006
    cheers.. take ur time
    Rides:
    1974 TA22 Celica 2T-GEU - Gone
    1989 ST162R Celica 3S-GE - Stock Daily
    2005 Honda CB250 - New Toy
    New Zealand
    OK, had a look this morning and traced everything -
    1. Runs to charcoal canister
    2. Runs to looks like a thermo switch on the block below the inlet manifold, it connects to the outer (left) port and then a line from the inner (right) port runs to the inner port of the dizzy (closest to the dizzy body).
    3. Runs to top of a vac switch behind the left strut tower (this is with the wiring coming out the bottom) as ta23-mbzq-nnr noted this will be the idle up for aircon. If you have no aircon I would block this and 4 off.
    4. Runs to the top of the vac switch mentioned above.
    5. There is another port just behind the 3 and 4 if you have a look around there. This runs to a T junction and feeds both the fuel pressure regulator and the outer top port of the vacuum advance in the dizzy.
    I do doubt that any of these lines are causing a major problem due to their small size. As I said before I would check for splits in the pipe from the AFM to the throttle body and also check the pipe from the bottom of the throttle body that then runs to a T, 1 section goes to the bottom of where 3 and 4 are, the second part goes to under the inlet manifold close the the head.
    Callum
    May 2006
    thx alot mate.. very thorough.. +rep
    wen i have some spare i shall print out n look into it.. will keep ya posted !
    Rides:
  1. 5M-E Vacuum lines.
    By hi-ace in forum Tech and Conversions
    Last Post: 15-01-2008, 09:26 PM
  2. How critical is a tight sealing vacuum hose?
    By JetspeedCamry in forum Tech and Conversions
    Last Post: 29-05-2006, 01:24 PM
  3. AE101 4AGZE wiring diagram Needed
    Last Post: 28-04-2006, 12:29 PM
  4. Vacuum relative to economy?
    By Andrew162 in forum Tech and Conversions
    Last Post: 19-01-2006, 09:03 PM
  5. 20V Brake Booster Vacuum Problems
    By ShiRi in forum Tech and Conversions
    Last Post: 15-12-2005, 07:06 PM
