Results 1 to 5 of 5
Thread: 5me valve clearance
    Default 5me valve clearance
    need the clearances for 5me , rockerarm to camshaft clearance actually
    Penrith BC
    Default Re: 5me valve clearance
    i think its 0.010" on the exhaust and 0.008" on the intake from memory...
    ../delete/ban
    tech moderator
    you set the gap in these motors between rocker arm and valve stem?
    Toymods Club Member #302 Backyard Mechanic hi-ace's Avatar
    Ok, the inlet side is 0.28mm or 0.0110in ex side is 0.35mm or 0.0138in.
    Measured between the valve stem & the rocker arm.
    This is the correct settings as per the 5 ME engine manual.
    If it feels good "DO IT" Unless it harms others.(or upsets the RTA)
    Enjoy what you have To Day,cause you can't take it with you.
    My old Hi-Ace
    thanks guys, and for anyone else looking for this info, the 0.28mm EX and 0.35mm IN are for a hot engine.
    thanks again
  2. Computer Engine Modelling, (18rg in particular)
    By jeffro ra28 in forum Tech and Conversions
    Last Post: 08-01-2006, 10:20 PM
