Results 1 to 6 of 6
Thread: Adaptive sumps?
    Junior Member Backyard Mechanic Kagetsu's Avatar
    NT
    Default Adaptive sumps?
    Just looking at the EPC, and pulled up the sump for the 1GZ (rather, small block diagramma) and noticed that it's flared out towards the flange end for the gearbox.
    Is it possible sometimes that one sump that Toyota use is the same as another on a different series engine? i understand that sometimes oil feeds have to be adapted, but just thought I'd check.
    ie. Has a 2JZ sump been attached to a 1UZ? etc?
    here's the 2JZ sump.
    http://www.toymods.net/forums/showthread.php?t=13047
    and here's the sump on the 1GZ
    It's probably a stupid questions, I'm just kind of reaching. ^_~
    Penrith BC
    Default Re: Adaptive sumps?
    ive never seen it happen between engine families
    10mm laser cut alloy adaper plate and bodgy up a jz sump - its got to be pretty damn close id imagine
    ../delete/ban
    tech moderator
    JZ sumps are much longer than UZ sumps, that much i can tell you! They won't bolt up!
    Yeah, but is it longer than a 1GZ sump?
    Today Im a Domestic Engineer Enchanter's Avatar
    Tas
    Heres a jz series front sump for visual comparison
    I have a rear aswell and will take some side by side pics when I pull it off the engine.
    NT
    No prolbem. I thought the UZ sump may have been a bit short. ^_^' Thanks guys, thought I'd check. ^_^'
  1. Custom Sumps - Ideas and Inspiration
    Last Post: 12-11-2006, 04:45 PM
