Results 16 to 18 of 18
Thread: Retrofitting A/C
    Opinionated Arsehole Backyard Mechanic
    Default Re: Retrofitting A/C
    Edited post.
    Nice..... Grease Monkey Rex_Kelway's Avatar
    Okay lads,
    Just a quick update for the benefit of the Toymods communtity (Because truly cares for His fellow Reputators )
    Rex can say for sure that the under dash box-ermajig is a 100% bolt in jorb. Almost too easy, Rex will likely be hit by a car sometime soon...
    Just unbolt the blower unit so it can be pushed to the side slighty, unscrew and remove that lump of ducting between the blower and the heater box, and stick that in the KE70 rally car if you are taking that route.
    The KE70 A/C box will fit into the AE86 perfectly, all the mounting points both on the car and the other units are there (just previously unused), and the grommeted holes in the firewall are also already there.
    Then bolt the blower back into position over the inlet for the A/C box and tighten the sealing clamp.
    Your lightweight AE86 is now several Kg's heavier, but on the way to being far more comfortable for that small amount of time that A/C is deaperately required .
    You shall hear more as the conversion unfolds.
    Rex
    AE86 Tuning Life Backyard Mechanic Garth AE86's Avatar
    Sydney NSW
    Awesome info rex
    be sure to keep us updated as im sure many of the ae86 boys with daily drivers are keen to get some AC on!
    Garth - 100% AE86 Addict
    AE86 - Levin & Trueno - The Legends Live On!
    'AE86' - Toyota Sprinter Trueno GTV
    "It's not a street car if you can't drive it on the street. The car has to be safe and fast on any road condition" - Keiichi Tsuchiya
