Hey guys,
Well while I am laid up at home sick I thought I'd post an update on the running of beast.
We got the car running pretty good with little backfiring or popping etc on saturday morning. Still got a strange issue with flooding I think (float level) but the strangeness is that plug 1 and 3 are running rich. I would have expected both plugs on 1 carby to be black as. So not sure exactly what to check for now (apart from resetting my float levels a bit lower).
We also decided to fix the clearance issue on the intake side, so took the cam out and faced all of the shims to what we calculated to give minimum clearnaces. Man that takes ages to face those little buggers by hand!!!. Burnt finger tips from the friction don't feel too good the next day
We re-aligned the cam gears etc as best we could without the little tool and they are a lot better now.
Biggest problem I have is that the big long curved guide is fubar so need to source replacements there (I think I will replace all the timing gear at once so I know for peace of mind that its done)
Anyway with the clearances closer to .24/.25 on the intake sides, fixing the cam alignment and with the buggered guide, this thing runs so much nicer. When I took it for a test it revved so much freer and felt a lot better.
I learnt how to use a dwell meter as well and the angle was spot on 54degrees which the toyota manual said it should be.
What I was thinking of doing is going electronic ignition by way of some of the posts I've seen on here which is an 18rc housing and 21 or 22r dizzy insides.
A bit more playing and fine tuning after the timing gear is replaced and I think I might have a nice little rocket
Any tips on which guides can be used from other motors etc would be handy. I've been reading the interchangeable oddities thread but am still unclear which guide can be used with a bit of massaging etc.
Thanks everyone for their tips and info, with your help and my friends I have learnt a lot about these toyota twincams.
Dave
