Page 3 of 3 FirstFirst 123
Results 31 to 35 of 35
Thread: How good is a 7AG?
    Default Re: How good is a 7AG?
    if sump clearance is an issue......
    DRY SUMP
    problem solved!
    Quote Originally Posted by Hiro
    Whilst technically making the whole engine taller, since the sump is below the engine mounts (and assuming you keep the standard A-series mounts) wouldn't this NOT affect the "height" (ie for bonnet clearances) of the engine?. Unless it also brings up crossmember clearance issues, the extra sump depth (7A is a 2-piece sump) shouldn't be an issue
    Yeah, but from BigPerms experience with putting an AE71 crossmember in a RA23 the height of the sump does make a difference. Hence i was taking it into account.
    Junior Member Backyard Mechanic Valkyrie's Avatar
    Tasmania
    I've got plenty of room from the bonnet with a 4AGZE in my TA22.
    I don't think you will have problems with the extra 25mm.
    I used 4A engine mounts and cut'n'shut factory 2T engine mounts.
    Just found this on another forum, thought I'd add it for reference..
    First post:
    Compression ratio depends on which head gasket you use. 7a (0.6mm) or 4a (1.2mm)
    Stock bigport 4A-GE = 9.4:1
    Stock smallport 4A-GE = 10.3:1
    7A-G, bigport pistons, stock deck height, 7A-FE head gasket = 10.3:1
    7A-G, bigport pistons, block decked .024" (0.6mm), 4A-GE HG = 10.3:1
    7A-G, bigport pistons, stock deck height, 4A-GE head gasket = 9.7:1
    7A-G, smallport pistons, stock deck height, 7A-FE head gasket = 11.3:1
    7A-G, smallport pistons, block decked .024" (0.6mm), 4A-GE HG = 11.3:1
    7A-G, smallport pistons, stock deck height, 4A-GE head gasket = 10.6:1
    7A-G, 8.0:1 early GZE pistons, stock deck height, 7A-FE head gasket = 8.8:1
    7A-G, 8.9:1 early GZE pistons, stock deck height, 7A-FE head gasket = 9.8:1
    7A-GE with stock 7A block, silvertop pistons and head, 7A 0.6mm HG = 11.55:1
    7A-GE with stock 7A block, silvertop pistons and head, TRD 0.8mm HG = 11.48:1
    7A-GE with stock 7A block, silvertop pistons and head, 4A 1.2mm HG = 11.35:1
    Second post:
    Jeff, my brain is fried. I have been up since half past February. But I believe the 7A block is about 15mm taller than the 4A block.
    Uhh wait, I have both 4A and 7A rods in the garage...let me go measure them.
    7A: 132.5mm
    4A: 122mm
    Note that I'm pretty tired, and am eyeballing the 4A rod just a little bit, since it has a piston on it and I can't really get the caliper on it properly. I came up with 122.5mm, but Jun lists it at 122mm:
    http://www.junauto.co.jp/products/cy.../index.html?en
    OK, might as well do the math...
    7A deck height = compression height + 0.6mm (pistons below deck at TDC) + 132.5 + 42.75 (85.5mm stroke /2) = compression height + 175.85mm
    4A deck height = compression height + 0 (pistons dero deck at TDC) + 122 + 38.5 (77mm stroke /2) = compression height + 160.5
    So I was close. A stock 7A block should be 15.35mm taller than a stock 4A block.
    Interesting, i have some 4A smallport pistons lying around, and have a 7AFE on the way.
  1. Who is good with WOLF3d In sydney?
    By KE25 RACER in forum Tech and Conversions
    Last Post: 29-05-2006, 01:20 PM
