Results 16 to 22 of 22
Thread: Advice on wheels and suspension for MA61
    Default Re: Advice on wheels and suspension for MA61
    lol toymods love is in the air.
    time to pick out some wheels now?
    I have a pet Backyard Mechanic Gibbon's Avatar
    Aug 2006
    Damn straight
    Now - to find a low offset 16" rim....
    wget -r http://www.toymods.net | grep -i "1jz MA61"
    1 Result found:
    Gibbons MA61 + 1JZ
    Quote Originally Posted by Gibbon
    Mate - you are a goddam legend - rang the dude listed in your link - hubs, rotors and calipers are on the way.
    So with 5 mins effort we found you some MS123 hubs did I just prove my point lol.
    If in doubt power out
    JZA80 Convert Backyard Mechanic
    Damn straight
    Anything from pre-AU falcon will fit. Check this thread for a bit more info:
    http://www.toymods.net/forums/showthread.php?t=2173
    Hi
    At last my finances are in order to start work on my MA61 - I thought I would do things the wrong way around, and do the brakes and the suspension before the engine.
    What's wrong with this?
    I think its the RIGHT way to do it.
    Make sure that your chassis can handle the power before upgrading.
    That way you won't have to baby the car as much or have to make allowances once you've got more poke.
    My car with 300mm discs, 4 spots & upgraded suspension (& < 60kW ATW) has kept up with a tweaked Corolla Sportivo in the twisties.... (as long as its not uphill )
    Aug 2006
    I guess that sarcasm doesn't translate across the web very well
    I only said it this way as it seems that normally the engine is done first, with the rest done after.
    I understand it's the right way to do it - I was just trying out some humour. I'll stop doing that now.
    1 Result found:
    Gibbons MA61 + 1JZ
    Lol, na humour dosnt work very well over the net sometimes, try adding some that always helps
  1. Bump Steer!
    Last Post: 19-07-2006, 07:16 PM
  2. Your suspension & you...
    Last Post: 23-05-2006, 07:41 AM
  3. suspension noises
    Last Post: 11-03-2006, 03:33 PM
