copy and paste:
I am currently doing my PhD in the optimisation of automotive airboxes, and can confirm that this is one of the most frequently misundersttod aspects of airbox performance. Many believe that the airbox should speed the air up, to 'ram' it into the cylinders more quickly, but as your friend pointed out, this is not true.
<boring PhD mode on>
The airbox tries to slow the air down to as low a velocity as possible. This results in the air having a higher pressure, increasing the pressure difference between inlet and cylinder and so pushes more air into the cylinder. Apologies to those who know all this, but I am just chuffed that my studies are actually relevant to a discussion!
One of the other main difficulties with airbox design is to try to ensure that all the cylinders get the same airflow into them. If you look at the Lola T370 and The lotus 72 with the horribly ugly airbox, you can see that for the air to flow in the inlet and fill the 'front' cylinder pair it would have to change direction very quickly... this probably didn't happen and so the front cylinders probably ran rich because they didn't get enough air.
The ligier airbox posted by philippe charuest looks like a much better design - the air changes direction relatviely gradually and then feeds a plenum at the bottom of the duct. Although this would probably still cause the front and back cylinder pairs to run rich, the problem wouldn't be anywhere near as bad as the other two I mentioned.
<boring PhD mode off>
im way to busy to worry at the moment.
), or some people just whack filters over the carbs without trumpets? I remember the older generation F1 cars having a stack of trumpets and no plenum.... but was this before they understood the dynamics of plenums, or (as mentioned) at high rpm (which the F1 engines would be doing for most of the race) such direct intake of air works better than having a plenum?
