the mismatched pair won't dramatically affect the idle, it's the light load driving that will be horrible due to the uneven progreesion holes. with a traditoinal dizzy 14 degrees at idle should be fine.
now pull off the carbs, check the manifold is true, make sure the seals are in good nick and reassemble carefully with nice even torques. when you get rid of the vac leaks, then tune the car. when you get this far, have a go on the previous advice. if you get stuck again, put another post up.
but there's nothin like the induction gargle comin from the throats of those things. its music to my ears.
