If you are loosing oil pressure due to worn components shimming the relief valve will have no effect.
Relief valve will only open when pump capacity exceeds the bleed off fcapacity rom the bearing clearances, likely not to be happening if engine is worn.
Higher viscosity oil may help but is only a band aid fix.
regards
jon
