Results 46 to 52 of 52
Thread: how can a BHG cause overheating?
  1. #46
    Default Re: how can a BHG cause overheating?
    Quote Originally Posted by SL666
    and 7m's because of some other deficiency...
    I believe this is caused by a change in head gasket material properties and the torque required for the head bolts not being changed to reflect that. It is why people say to torque them so much higher than stock.
    http://www.toymods.net/forums/showthread.php?t=44227
    80 ft/lb with moly
    120 with 30 weight oil.
    Stock spec is 58 ft/lb for both GE and GTE (though i am unsure if the TSRM i have has been updated to reflect the higher torque required).
  2. #47
    There you go exact reasons
  3. #48
    Heat cycles of an engine also wear away on their longevity ie making them brittle over time. Generally though they do last a fairly long time.
  4. #49
    Breaker OfThe Unbreakable Backyard Mechanic Herus's Avatar
    Feb 2007
    , ea falcon 6's coz they are crap..
    Actually cause by Ford not having a long enough expand on the bolts when they heat up.
    AU head bolts tend to fix this issue.
    Herus
    Member's ride thread!
    Joined Team BHG, 19/7/2008
    Joined Team JZX83, 15/11/08
  5. #50
    what was the go with the cracking and warping then? - or was that resultant of the running out of water and cooking?
  6. #51
    BHG drops water, head runs hot, crack or warps etc.
  7. #52
    Cool, thanks for those answers, guys. My MS123 has its original 5M-E, 185K on the clock, has been regularly serviced, including cooling system, and is only run on premium unleaded.
    Is this one any more likely to do a gasket than any other vehicle?
    Buddha
    "He's not the Messiah, he's a very naughty boy" - Monty Python
    Mine: 2012 Yaris YR 5 door
    Missus: 2004 Corolla Ascent Wagon
    Project: 1996 Falcon XR8
  1. 4a-c Ae82 Overheating Problem!!!
    By nos4ag in forum Tech and Conversions
    Last Post: 07-11-2008, 08:27 PM
  2. overheating 2SC
    By RA60 KID in forum Tech and Conversions
    Last Post: 03-09-2007, 12:59 PM
  3. Cooling Systems - Overheating Problems.
  4. Overheating Phantom
    By kwayzivietnamese in forum Tech and Conversions
    Last Post: 06-04-2006, 10:55 PM
  5. 3S-GTE overheating
    Last Post: 23-12-2005, 03:41 PM
