Results 16 to 25 of 25
Thread: Pics needed: 1uz oil filter / air con fittement
    Default Re: Pics needed: 1uz oil filter / air con fittement
    A fleetguard LF3826 filter is 62 mm long
    Penrith BC
    im running a mocal remote filter unit which ive made a base for and welded to the chassis rail just behind the radiator... runs a big mofo Z9
    my issue now is simple getting x2 -12AN lines out from the side of the block under the air con, up to the filter location
    ../delete/ban
    tech moderator
    Junior Member Grease Monkey MacroP's Avatar
    Quote Originally Posted by ed_jza80
    Hey dude, I have a custom 1UZ oil manifold block that a mate made for me on a CNC mill.
    It's has 3/8" BSP threads from memory. I was going to use a remote setup at one stage.
    Here's the pic,
    http://img22.imageshack.us/my.php?im...anifold5eo.jpg
    I never ended up using it as I opted to use a 2UZ oil setup which cleared my front sway bar in my 1UZ MX83 conversion.
    If you are stuck, I could try and dig it out from my parts bin for you. It's around somewhere.
    MX83 1UZ Conversion. UZZ31 engine, UCF10 Sump, UZS131 Tranny and engine fan idler. Custom exhaust and 147rwKWs.
    Does someone have a pic of the 2UZ oil filter stalk?
    One more pic.
    Mos.
    Penrith BC
    cheers mos
    looks like the oil stalk axits on the tangent to the air con. so the available room will only get bigger from the mounting plate outwards = a good thing!
    thanks
    ed
    ../delete/ban
    tech moderator
    Quote Originally Posted by gianttomato
    Fitted
    Off the car.
    *pics no longer work
    Penrith BC
    eds solution:
    ../delete/ban
    tech moderator
    Cruz, need those pics a bit bigger. Thanks mate.
