Results 1 to 12 of 12
Thread: Adjusting timing on a 1g..
    90 Millcrest st
    Default Adjusting timing on a 1g..
    Hi guys ive got a blitz k3t turbo on my 1g, running around 10psi an was just wondering if i should adjust the timing to suit the bigger turbo, and if so how?
    Default Re: Adjusting timing on a 1g..
    I wouldn't adjust it personally as it tends to affect idle quality and all sorts of stuff, i'd just be leaving it as is and getting an aftermarket ECU.
    90 Millcrest st
    yeh thats probably a good idea, jus kinda have a feeling its been tampered with before, cars always had a high idle, around 1000rpm for some reason
    Set it to 10 degrees BTDC in diagnostics mode and leave it there Clean your ISCV too, sometimes they get gummed up.
    90 Millcrest st
    hm how would i go about doing that? Is that just the standard timing?
    Bridge the T and E1 pins on the diagnostics plug which will lock the timing. Set the timing to 10 degrees (yep, thats factory) and then unbridge the pins.
    As for cleaning the ISCV, have a search, there is a whole thread about it with pics.
    90 Millcrest st
    ok cool will do, thanks for your help
    No worries.
    don't spose you know where those pins go to on the ECU?
    Hello.
    Western Aus
    continuity test ftw.
    Eldar.O.
    would do if i had diag plugs.
    Hello.
    T and earth
  1. 2tg - playing with cam adjustments - help!!
    Last Post: 23-08-2006, 06:36 AM
  2. Timing on a 3SGE
    By WindeX in forum Tech and Conversions
    Last Post: 29-06-2006, 01:19 PM
  3. checking timing on car with coil on plug setup
    Last Post: 23-02-2006, 06:52 PM
