Page 1 of 3 123 LastLast
Results 1 to 15 of 35
Thread: 2jz Vvt Ftl!!!!!!
    Forum Sponsor Automotive Encyclopaedia dori dori's Avatar
    Default 2jz Vvt Ftl!!!!!!
    Hey Guys, just trying to find out more infor for my 2JZ VVT-i engine and hoping you can help.
    Aparently Haltech can't vary the intake cam and feel that its a mechanical problem and nothing to do with the ECU side of things.
    I have pulled out the solenoid and put 12V to it and it triggers the pluger fine. I then refitted the soleniod with the engine running and applied 12V again thinking that the engine would want to stall. This did not happen - it ran fine. I've been told by a mate who knows his Toyotas that if it didn't want to stall the solenoid is busted and to buy a new one.
    Anyone care to comment on my findings? I have no issue buying a new solenoid they are cheap from Castle Hill Toyota and they even have one in stock
    But if this doesn't fix it i'll be less than impressed.
    Default Re: 2jz Vvt Ftl!!!!!!
    dude - your best friend in the whole world will be the UK supra forums. those guys know a LOT about the vvti 2jz-gte engines (as they got them locally delivered)
    Penrith BC
    why on earth would engaging the vvti want to stall the engine?? wtf?!!
    and perhaps you should rename the thread 'Haltech FTL'
    ../delete/ban
    tech moderator
    vic
    Thats the the way Lexus trained people are taught how to do it , Its even in the Lexus workshop manual , apply battery voltage to the solonoid , the engine should run rough or stall
    Dave
    Penrith BC
    ok - post edited
    but i stand by my scepticism - all that enabling the vvti will do is open up the overlap and allow a bit of leak down and blow through. sure as shit ill be suprised if it stalls
    ../delete/ban
    tech moderator
    Junior Member Grease Monkey teamdrinkalot's Avatar
    Aug 2006
    Apparently the solenoid is energised during cranking of engine to allow more breathing for start up, once the engine fires upo it is turned off and than re-energised at approx 4000rpm.
    Since you have VVT-I, the standard computer uses the rear camshaft angle sensor to vary the operating times of the solenoid.
    Quote Originally Posted by teamdrinkalot
    are you 100% sure about this?? i'm looking at a similar VVT-i problem and this would answer part of the problem.. please confirm thanks !!
    Aug 2006
    Quote Originally Posted by Vios-GT_07
    Go to www.billzilla.org/vvtvtec.htm
    Today Im a Domestic Engineer Enchanter's Avatar
    Tas
    I believe VVT is an on off type of switching where as VVTi is continuously variable. VVTi is far harder to control and I dont know of a 2j with the simple VVT, only the VVTi.
    Edit: The Haltech can probably only control VVT.
    that would be because they only came with vvti
    AFAIK at the moment there's only two aftermarket ECU's that'll control VVT-i.
    Motec M400/600/800 and Autronic.
    what he said ^^
    Wolf V500 can do it.
    Won't be long before Adaptronic can too.
    and who buys something with a 2jz-gte vvti and hooks up a wolf to it?
    Penrith BC
    wolf v500 is getting a serious look-in to run the 1uz
    very very impressive piece of equipment
    ../delete/ban
    tech moderator
  1. 550cc US 2jz injectors into 1jz
    By Esselte in forum Tech and Conversions
    Last Post: 26-07-2007, 02:18 PM
  2. 1jz to 2jz
    By HIZOKU in forum Tech and Conversions
    Last Post: 30-11-2006, 07:52 AM
  3. 2JZ damaged, other options?
    By jzk25 in forum Tech and Conversions
    Last Post: 11-07-2006, 06:47 PM
  4. 1jz vs 2jz heads
    Last Post: 04-05-2006, 10:07 AM
