Results 16 to 30 of 35
Thread: 2jz Vvt Ftl!!!!!!
    Default Re: 2jz Vvt Ftl!!!!!!
    i would ring haltech and ask them can it do a fully variable solenoid control
    its not just on an off
    it is a varying pulse width modulation which i know haltech cannot do so far
    90% of ecus can only do on 100% and off which is vvt
    this is interesting.
    pulls up deck chair and esky of cold beer awaiting outcome.
    8.3 et PB 169 MPH PB
    Today Im a Domestic Engineer Enchanter's Avatar
    Tas
    Quote Originally Posted by Draven
    that would be because they only came with vvti
    Quote Originally Posted by Billzilla
    AFAIK at the moment there's only two aftermarket ECU's that'll control VVT-i.
    Motec M400/600/800 and Autronic.
    That was my point, the Haltech cant cut it.
    Does anyone know what the possibility would be of converting it to a VVT style of function at least until VVTi compatible stuff becomes affordable?
    Penrith BC
    Quote Originally Posted by Enchanter
    v500 and sm4 = affordable
    ../delete/ban
    tech moderator
    Forum Sponsor Automotive Encyclopaedia dori dori's Avatar
    Correction, run rough then.
    Not wanting to get into details but yes the Haltech can control VVT-i on Toyotas.
    My issue is that i'm trying to diagnos a possible faulty oil control solenoid without a manual or anyone else that has done it.
    quarantine is gay Backyard Mechanic rustyP's Avatar
    i still object to calling ftl for any 2jz
    the oil solenoid has just an on and off trigger but the std ecu pulses it very fast i presume
    i have seen from people asking me about things that alot fo tuners do not know how to tune these vvti with aftermarket ecus
    and another thing is that engine oil presure can also determine on the position of the vvti cam gear
    so its not just one thing to look at when adjusting them
    just have a speak to your tuner and ask them if they understand everything they prob do but i do get calls regarding this sort fo thing
    i have the vvti workshop manual but its in japanese
    Thanks Sideshow, appreceate the info. I am aware of the oil pressure side of things, but my original question had nothing to do with the ecu rather i am trying to diagnos a possible faulty control solenoid. The thing is that adjusting the inlet cam timing through the Haltech worked at the very begining of the conversion and now doesn't respond.
    Either way i'll buy the new solenoid and eliminate that as a problem and work my way forward.
    Would you mind if i had a look at the VVTi manual?
    Fava beans and chianti Backyard Mechanic AE86slut's Avatar
    New South Wales
    This is funny. Ask a simple question, get a million and one retarded answers that go nowhere in regards to actually helping with the problem.
    Having said that, Grant aka dori dori (wtf?) is equally retarded, so I'll re-ask his query for him.
    We are trying to get his VVTi (constantly variable, not on/off) on his 2J working. I agree with you Jim that it's most likely a series of pulses rather than a flat voltage supply that the solenoid normally recieves, although varying in frequency for different cam timing positions (obviously).
    The issue here is that we've triggered the solenoid with 12V with it out of the car, and witnessed it moving enough to do the job. When we refit it to the car and do the same, it should advance the cam timing and increase overlap etc with the result being either a rough idle, or a complete stall. This does not happen, even though we can hear the solenoid clicking away. Oil pressure is not an issue, so we need to know if there's anyone who has had enough EXPERIENCE with these motors to offer advice on something we may not have thought of.
    The ECU is a Haltech E11 V2. It and the programmers are up to speed on the whole VVTi thing, so that's not really an issue. That side of things doesn't even come into it at this stage anyway, as we just want to be able to hear that the actuation of the solenoid is actually doing something (said rough idle etc) before going any further.
    Any HELP would be appreciated.
    Jeremy.
    P.S. As Grant said, do you reckon we could have a squizz at the manual Jim? I live in Baulkham HIlls so could pick it up or something off you (I'm pretty sure you live in the same area?)
    We can translate it here at work.
    I am not a doctor, or a mechanic...
    A.K.A Otomoto
    All new - Fart!
    Quote Originally Posted by Vios-GT_07
    it was 10,000 kms b4 it saw the red-line.. but even then i seldom push it that hard unless i have to prove a point i.e. competition
    Junior Member Backyard Mechanic jonra23's Avatar
    Jun 2006
    So you have checked the oil solenoid and it apparently work, you say it has good oil pressure, you have hooked up powere and earth to solenoid with engine running and no change.
    That only leaves then the actual actuator, have you give it a bit of pressure with compressed air regulated down to say 40psi to see if you are getting actual movement.
    regards
    jon
    Penrith BC
    have you physically checked taht youve got free rotation of the camshaft within the vvti mechanism? ie nat gaulled with oil reside or something. if the solenoid is working, and oil pressure is up, it 'should' rotate...
    work down the line
    ../delete/ban
    tech moderator
    Cheers, Ed. Will do.
    I'm thinking that although the solenoid worked out of the engine it might be failing once load it applied.
    Penrith BC
    Quote Originally Posted by AE86slut
    settle down sunshine
    ../delete/ban
    tech moderator
    You assclowns better rep me up hardcore stylezz!!!!
    Otherwise:
    Quote Originally Posted by sideshow
    My old E6K can do a variable pulse width modulation with revs, it's used for boost control. Would that do the job?
    If you want to check if the VVT is working, mark the pulley in the off position grab a timing light and trigger the VVT, the strobe effect of the timing light should make it simple to see if anything is happening.
  1. 550cc US 2jz injectors into 1jz
    By Esselte in forum Tech and Conversions
    Last Post: 26-07-2007, 02:18 PM
  2. 1jz to 2jz
    Last Post: 30-11-2006, 07:52 AM
  3. 2JZ damaged, other options?
    By jzk25 in forum Tech and Conversions
    Last Post: 11-07-2006, 06:47 PM
  4. 1jz vs 2jz heads
    Last Post: 04-05-2006, 10:07 AM
