Results 1 to 7 of 7
Thread: F serires Diff - Corona Mk II
    Default F serires Diff - Corona Mk II
    Hi All.
    I have been advised that the diff centre out of an MA61 supra will fit into my Corona
    MK II F series diff.
    I just want to confirm this is the case before I purchase on.
    Spoke to some wreckers and they advised it will not fit as th MA61 is IRS.
    Is it a striaght swap or not?
    Thks
    Cyprus73.
    User Conversion King
    NWA
    Default Re: F serires Diff - Corona Mk II
    yep - it fits. thats what im running in my MX13 diff housing at the moment
    just need to double check your mkII actually has a F series diff. read the toyota compliance plate and look beside "trans/axle" it should say something like;
    the diff code is referring to the latter part.... the first part refers to the gearbox
    "W40 F302"
    or
    "W40 E302"
    let us know which it is
    edit;
    if it is this
    "W40 F302"
    then your good to go
    but.... if its this one....then bad luck
    "W40 E302"
    hello
    NWA
    Quote Originally Posted by cyprus73
    since when do wreckers know anything about toyotas?
    the T, G and F series IRS centres will fit the T, G and F series live axle banjos
    hello
    Yup, you don't become a wrecker because you're a rocket surgeon.
    From memory a few people here have put F series IRS centres in live axle housings, so it can definitely be done.
    Hi all.
    Its the F, I pulled it out of an MX13 as I have the MX22.
    Good, so its a straight swap, now I have to find one?
    Cheers.
    NWA
    have fun finding one in good nick. brand new torsens are pretty cheap....about 600ish. someone in NSW distributes them apparently
    hello
    Act
    Yeah i'm ruinning a RA65 diff ratio (which came from IRS) with a True trak F series centre all in a Crown live axle.
    Pube found the true traks in granville for around $700 i think which is what i paid for mine in the first group buy.
  1. changing the gear ratio's in hilux diff.
  2. Diff change in RT104 corona
    By lightning in forum Tech and Conversions
    Last Post: 23-09-2006, 12:42 PM
  3. corona diff ratios ?
    By sam-131 in forum Tech and Conversions
    Last Post: 14-06-2006, 01:07 AM
  4. 1970's Mark II Corona - E or F Series Diff?
    By Grant in forum Tech and Conversions
    Last Post: 22-05-2006, 06:58 PM
