Results 16 to 30 of 36
Thread: 5ME - no power ( less than usual :oP )
    Western Aus
    Default Re: 5ME - no power ( less than usual :oP )
    from memory, two of the plugs were carboned up, the rest were fine, the thing idled like an 8, plugs were taken out, compression was checked, 175 psi on each cylinder, +/- 5 psi.
    plugs were put back in, car was started to do the TK test for BHG, the thing idled alot smoother, as time went on, it got smoother and smoother, byt the time all testing was done, it ran smoother than my 7M.
    understandable, i found out that day i have a BHG :/
    best of luck fixing it damo.
    Eldar.O.
    the only time I had a 5m-e act like that was when it was on the cold side and the earthing was bad. The thing would idle ok-ish, as soon as you tried to put any boot in, the thing would belch black smoke like mad, although you couldn't see it in the rear vision mirror, had to follow from behind to see.
    check piping between afm->t/b could be hidden cracks esp under the exhaust manifold.
    good luck
    James.
    If problem continues - discard engine and find something better?
    cheers,
    Charles.
    hahahaha - Thanks Charles..
    yeah, its on the cards - but not in the budget at the moment.. so have to get the 5M drivable for now..
    Thanks guys.. will follow up on suggestions..
    Damo
    Go with what Viper said, Stitty had the same problem.
    Make sure the block, head and body are all properly earthed to the battery.
    Make sure the ignitor is properly earthed too.
    Bad earth means the spark blows out under load.
    Quote Originally Posted by Robbos_Toyotas
    change that valve dude, i bet my left nut thats your problem! just need to make sure your spares arent rooted as well, as its a common failure part!
    Blake.. you owe me your left nut!
    I only had a small time frame to play last night so I changed that air bypass valve as described. No change whatsoever..
    Dam - I was hoping for the quick fix.
    I've had a few people now suggest the ignition side of things.. so I'll next change all the plugs, leads, coil, ignitor etc (when I have some time).. see if that helps..
    cheers guys, will keep you updated
    Damo
    Quote Originally Posted by WA_TRD_83
    this requires pics as proof of delivery... not that i have any desire to see blake's gonads... but a man's gotta live up to his word
    wow im very surprised!!! i thought it was a dead set giveaway! Ah well, my bad sorry dude...time to upgrade to 7mge hehehe
    Junior Member Backyard Mechanic M.J.H's Avatar
    Does the thing free rev okay?
    or does it do the same type of thing with no load?
    Western Aus
    free revs fine.
    Eldar.O.
    Genuine Hotty. Conversion King old_mr2's Avatar
    I reckon its some sort of exhaust blockage. But with no chance of cat converter break up i dont know.....
    thorttle cable? seem ok?
    could be a bit on the loose side, warn out..
    would explain it i reckon
    Grant.
    free revs fine.
    Eldar.O.
    Really silly thing to suggest but have you jacked up the back of the car to try running it through the gears?
    Couldn't be a brke or something stuck on is it.
    I think you mentioned it had sat for a while yes?
    Back to basics - fuel and spark! Check the resistance of the plug wires with a multimeter. Try throwing in another set of plugs if you have some spares lying around (or can borrow some).
    And the winner is Norbie!!
    as he said - back to basics..
    I went to replace all the ignition system last night.
    Started simple and replaced the leads with some quality Top Gun leads I had laying around..
    HAY PRESTO! - Throttle response and power back!!..
    I couldn't believe it was that easy - I just laughed at myself for not trying it earlier.
    I guess the moral here is - assume nothing.
    I assumed that the leads were new.. or newish.. but for all I know, they could have been the original ones that came with the car?! At least 2 or 3 must have not been sparking properly for that sort of power loss..
    But the good thing is, now its all sorted, I have super responsive 5M power.
    Thanks to all that responded with their suggestions.. +rep coming your way
    (mods can close this thread when they are ready)
    Damo
    TRD83
    Good to hear you got it sorted. Simple fixes are always the best.
    Oh and Norbie FTW.
    glad to hear its fixed and it wasn't an expensive fix either
  1. Modifying Camry Engine 1MZ-FE
    By Camry_Grande in forum Tech and Conversions
    Last Post: 20-11-2011, 12:44 AM
  2. Article: BHP vs HP vs kW and other power conversions
    Last Post: 06-06-2006, 11:37 PM
  3. Article: Torque / Work / Power
    Last Post: 02-06-2006, 01:03 PM
  4. where to get power, but only when engine is spinning.
    Last Post: 26-03-2006, 08:39 PM
  5. run your power steer from hyd water pump!!
    By 1jzracing in forum Tech and Conversions
    Last Post: 26-02-2006, 09:42 PM
