Use an AC motor!!!!! Hehehehe, onya shiny!!!!![]()
If its a multi-coil motor you can just switch on/off the extra coils. This is how your wiper motor works. It runs on a couple of coils (stator coils) and you switch in an extra coil and it goes half the speed.
If you want a few different speed/power settings, rather than use PWM you can use an LM138 5amp adjustable regulator. All you need is to switch a few different resistors for the adjustor and you can select any votlage you want, depending on the resistor. These are not power resistors - just your stock 1/4-1/2W resistor 'cos the LM138 regulator is doing the work and taking the load.
The spec sheet for the LM138....
http://mechatronics.mech.northwester...ata%20sheet%22
If you want a smooth and fully variable speed range then PWM is the best solution. If you are happy with three or four set speeds then then LM138 circuit would be fine.
Mind you, a 5A regulator means your motor has to rated at 60W or less. If it's more then you need to add a power trannie to help the LM138 deliver more than 5A. Not a big or complicated thing to do - but it adds a few dollars to the final circuit.
So, you have to decide if your application requires PWM or an adjustable regulator.
seeyuzz
river
They get brittle from all the heat cycling and they're shaped to get rid of all the heat they produce.
