Results 16 to 22 of 22
Thread: Removing boost cut on gen1 3S-GTE
    Default Re: Removing boost cut on gen1 3S-GTE
    hey dood, our 3s are JDM mine was from a halfcut.. as would been yours, we dont have that sensor, i no what toobs is talking about now.. dont bother disconnecting anything mate u me piggy and DV seem to have the problem..
    What is autosalon? Sounds kinda homo.
    Quote Originally Posted by tooch
    It's extremely homo. Basically a whole lot of sh1t cars, with ugly wheels, and a lot of 16-20 year old rockstars with trendy mullets and gay shirts.
    Slayer Of Toymods Wookie Slayers
    W.A.
    Hmm there HAS to be something that initiates the cut though, a voltage somewhere, all we have to do is find it If there is defianantly no extra sensor of any kind anywhere then it is going to most certainly be involed with the AFM. If i get motivated enough i'l start checking output voltages etc on the AFm and try to narrow it down.
    This sucks balls!!! i want 15psi
    Matty
    It has to be down to AFM voltage then Matty.
    W.A.
    Yep totally agree man, one of those 5 or 7 wires is going to be the key, it may even be as simple as 1 wire, it may be triggered by a on off kind of switch when the AFM hits full flow it hits the boost cut switch as such.
    Junior Member Backyard Mechanic jonra23's Avatar
    Jun 2006
    Asuming pinout is the same for most toyate AFM (3s &2vz camry manual shown)
    Looks like the VS wire would be the one to put interceptor in if fuel cut is calculated off airflow.
    This will mess with the way the ECU calculates fuel and ignition requirements, it will lean off mixture and advance spark if you tell the ECU that less air is entering for same sensed rpm, this may be good or bad depending on how car is currently running.
    regards
    jon
    mmmmmmmmmm nice pinout diagram dood !
    yeh i wonder how the ECU would like it..
    i think wildsupra should try it first as our test GTE ( LAB RAT )
    W.A.
    HAHHA thanks jorrs
    Jonra23, it does appear that you are correct.
    I pulled my AFM apart and did some testing, got a few mixed results. I "think" i can get rid of boost cut completely, however it will require modifying an AFM, which im not real keen to do to mine just at the moment. if any1 would like to donate an AFM to me i will try it and see what happens.
    Might try rigging something up for that wire as a test first. Its gunna be hit and miss though
    Hmm fixing my supra at the moment, if i get a chance i'l have a play with that wire
    Matty
  1. Autronic SMC boost control help
    Last Post: 27-08-2006, 10:16 PM
  2. tt soarer over boosting
    By kremsra28 in forum Tech and Conversions
    Last Post: 07-06-2006, 09:34 PM
  3. Boost Leak Tester
  4. wiring up a turbosmart duel stage boost controller?
    By -=DV=- in forum Tech and Conversions
    Last Post: 15-03-2006, 03:53 PM
  5. Replies: 22
    Last Post: 15-03-2006, 01:24 AM
