Results 16 to 30 of 45
Thread: 1JZ- how to tell it's going into closed loop?
    Default Re: 1JZ- how to tell it's going into closed loop?
    are you throwing your petrol out the window? something very wrong there!
    chuck it on dyno just for exhaust/AFR check...
    it's either seriously pig rich (andyou have a black rear bumper), or...
    you maye have a fuel leak somewhere....
    or you need lighter shoes
    what about highway cruising?
    W.A.
    Quote Originally Posted by EvilJack
    say hello to my little friend...
    ECU Diagnostic Codes
    Trouble Procedures
    These are codes for the 2J
    Are they the same as the 1J for sure?
    i get bang on 16L / 100k's every single time, no matter how i drive nor how much boost i run. I've got that since i put the motor in, even through all my mods it has still remained the same.
    But on the bright side, my N/A 7M used to get 19L / 100k's
    Yep go figure that one out for me and let me know why
    Matty
    veilside kit increasing drag?
    W.A.
    HAHAHAH it didnt change when the wing or any other bits of the kit were added
    But i'd say extra drag is still there anyways
    is that giving it some? what if you drive gently? (grandma style)
    if your AFR's are good everywhere, then it is either heavy car, huge amounts of drag (unlikely ), or right foot behaviour?
    16L/100km on highway is pretty bad... but it depends how fast you are going
    Junior Member Grease Monkey EvilJack's Avatar
    State
    Quote Originally Posted by Wildsupra
    Matty
    yes they are the same, most codes right through the toyota range mean the same thing
    i do roughly 14L / 100km for normal daily driving and 12L / 100km for highway but then again i dont run an oxy sensor
    Junior Member Backyard Mechanic cptsideways's Avatar
    Dorset
    Buy a $20 AFR gauge & wire it in, its easy to spot when it goes open/closed loop. My 1G is open loop to 4k & no boost, then closed loop rich past 4K & any boost.
    W.A.
    Its the same whether im giving it full boot everywhere or goin nanna styles.
    Even let my girl drive it for a week and she got the same as well.
    I know for sure she doesnt rev it to limiter every gear change....like i do, so thats one difference in our style of driving, yet still with the same fuel usage.
    I thought my fuel gauge and odometer must have been connected some how, but now my speedo cable broke and i still seem to use fuel, so no luck there
    Matty
    to test if your OXY sensor is actually working (closed loop) whilst in cruise conditions.... hook up an AFR gauge to it - it should swing back and forward from rich to lean
    I will add my figures to this thread next Thursday after I have done a 400km round trip
    1280kg helps my cause but 2600rpm at 100kms doesn't compared to everyone with their 3.9:1 diffs! Hoping for 10L/100km
    QUICKEST 1JZ'S IN OZ
    Is that 1280kg with you in it or without?
    that's with my fat ass and a full tank of fuel
    Is you a big bastard or a little tacker?
    Quote Originally Posted by JustCallMeFrank
    Is you a big bastard or a little tacker? Aiight
    Fixed!.....
  1. 1jz to 2jz
  2. 1jz and Haltech e6k
    Last Post: 10-10-2006, 04:25 AM
  3. gearbox for 1jz
    By Azzamk2 in forum Tech and Conversions
    Last Post: 18-07-2006, 07:51 PM
  4. 1jz vs 2jz heads
