Results 31 to 45 of 60
Thread: 4age cooling system problems
    Default Re: 4age cooling system problems
    Yeah, my auto AE71 remanufactured rad copes admirably even with the race engine. Keeps it at about 80* even at Mallala.
    good to hear it's all sorted out...
    come the next drift event.. if there are any dramas .. just get a thermostat that opens up earlier... otherwise take it out.. then after the drift put it back in..
    but IMO the engine will cop it bad without a thermostat at a drift event... then again i have been proven wrong so we'll see
    CAE86 Grease Monkey ae95's Avatar
    maybe it was not such a good idea to run 100% toyota red without mixing in some water
    Quote Originally Posted by ae95
    where's YLD when u need him to quote this?
    one of the old school tricks of "keeping it cool" is to run a higher mix of water to coolant to keep engine cool at the cost of corroding the head.. but ideally you should follow the directions on the bottle with regards to mixture..
    wa
    haha Ian (ae95) you dumbass
    My Corolla ! - 4AGTE
    KP61 - 4AGE
    Raastler Grease Monkey
    The problem is still there guys, It was fine for awhile drove it to work today, was fine, but on the way home started getting hot, then it overheated almost, got home just intime.
    Cracked or warped head or gasket creep. as ill say again!
    you pump cant be that gone without noticing etc go
  8. #38
    Western Aus
    Quote Originally Posted by Adsport
    cooling systems does not pressurise at all. overflow bottle has not gained/lost any fluid. coolant is bright green with no bubbles/gasses/frothing
    am i the only person that has seen this, and is pretty much certain that this is either the cause of the problem, or a product of it?!
    you sure you rad cap isnt bung matt?
    Eldar.O.
  9. #39
    No one is that silly
  10. #40
    rad cap isnt bunged.
  11. #41
    since everyone else is guessing
    thermostat does two jobs. one, to slow water a lot when cold, adn two, to provide some resistance when hot, so that the water pump can pressurise the block a bit, and reduce the chance of hotspots. just removing the centre might still be ok. maybe it still lets too much water thru tho... you could try with a plate with a smaller hole.. say, half the area. see what happens?
    earlier opening thermostat will do nothing for an overheating engine.. (once it's open... it7s open it just stops the engine from being too cold.. but a lower cold than usual)
    the seal of the water pump should be fine. there is little chance it could suck in air (unless there was a net vacuum in the block?) if water is not leaking form there, leave it alone
    progkamol, your fan switch (the thing the plug was pulled off) is either dead, or the threads are dirty. pull the sensor out, clean the threads, reinstall, MAKING SURE there is electrical contact between the sensor body and the thing it screws into.
    (as said before.. stop letting your mates touch your engines they have no idea )
    back to problem..
    if it was getting that hot, then you would lose some fluid by expansion... or if it got really hot, by boiling (but only really hot). is there a chance that when the sender was installed, it doesn't have as good contact with the head as before? have you checked with a different temp meter that the temps are actually that high? (ie, stick k-type thermocouple in the radiator water and measure directly)
    i would also check the compression yourself.. 150 seems a fair bit low
    160rwhp? so it's not just a 100kw then . check your radiator cap is functioning or borrow one/buy one.
    check radiator is actually getting hot (by hand, and the water by thermocouple)
    check the temp sender. pull it out and stick in hot water, with a thermocouple, and check it is reading correctly... it could have been damaged during the swap (but unlikely)
    check for hotspots, check water lines etc..
    check compression.
    could there be crack from exhaust into coolant? but not losing any? hmm
    could you have too much timing... since now you have (supposedly, but not from the figures given) higher compression, then you might need to back off timing a bit, or add a bit more fuel (check AFR's)....
    anything else?
  12. #42
    I aint guessing, just going by what has been done. it has a thermostat in it now!
    Very hard when you not looking at it yourself
    turbo i missed that! to easy
  13. #43
    but it's turbo right?
    still, compression is low for an unopened 100kw 4AG...
    quoted for posterity
    Quote Originally Posted by kingmick
    it would be 160hp at the wheels on a great dyno! hhahahahahah thats better than a lot of 7age 1.9litre race motors
    aftermarket management.
    did you swap the same injectors over when you changed engines?
  14. #44
    SC14'd Member Domestic Engineer nick.parker's Avatar
    Canterbury
    On the 4AGE, the thermostat regulates the BLOCK water temperature by mixing water that has been to the radiator and come back (cold) with water from the 'heater outlet' on the block (hot). It is just a temperature dependant 'mixer' of sorts.
    The point of letting the system become pressurized (which occurs only becasue the water exceeds 100degs at standard pressure and the cooling system is SEALED) is ONLY to increase the boiling temperature of the coolant, and stop 'steam pockets' forming. As for exampling sitting still and idling on a 40degC day the water can exceed 100degress. The pump does not pressurise the cooling system, it only circulates water.
    When the engine is very cold, the hot water from the main water outlet is STALLED by the closed thermostat (closed because its cold), BUT the 'heater outlet' is routed to the other side of the thermostat (which effectively enables the thermostat to sense engine temperature when engine is 'cold'), and that hot water returns straight back into the block - no water goes to the radiator. An 'always circulating' path is used by your heater too, so it starts working as early as possible after cold engine startup.
    When the water is hot enough, the thermostat beings to open and so long as sufficient heat is always removed from the hot water by the radiator, the system will be regulated by the simple but ingenious THERMOSTAT which opens more when the engine is too hot, to add more cold water, or closes more when too cold to allow the temperature to increase.
    The system is most restrictive towards the pump when the engine is cold. And when the engine is HOT the water can most easily circulate since the radiator path will be atleast partially open.
    The thing to note is water is NEVER stationary inside the block, but it IS stationary inside the radiator when the engine is a fair bit colder than the thermostat setpoint.
    Does the water in your radiator get hot?
    Regards, Nick
    == 4AGZE SC14 Supercharged ==
  15. #45
    it has ran as a turbo car before on the old engine, everything was fine, atm its running 8deg btdc previously it was like 12deg. We have put the thermostat in, but thats when it overheated again yesterday. most of the things you have suggested are ok and or have been checked.
  1. Sam-Q's 20V RWD Cooling System Guide
    By Sam_Q in forum Engine & Driveline Conversions
    Last Post: 27-03-2007, 06:08 AM
  2. Cooling Systems - Overheating Problems.
    Last Post: 24-06-2006, 09:40 PM
  3. Your suspension & you...
    Last Post: 23-05-2006, 08:41 AM
  4. 4AGE cooling system - an observation
    By roadsailing in forum Tech and Conversions
    Last Post: 18-12-2005, 12:01 PM
