I tried my method earlier tonight, I ripped out the tailshaft pulled out the plugs
had it in 5th, turned engine over one turn by hand to take up slack, turn the cam wheel
around to line up with the mark on the output, turn engine over one turn again and the mark
on the shaft was pointing at about 308.
even if theres backlash theres not going to be enough to confuse the difference between
a 55 and 58, about 25 degrees difference.
cheers.
Edit, i treated the gearbox as if i was timing a dizzy, turn one way only otherwise you time
on backlash as you mentioned.
please check..
