Page 2 of 5 FirstFirst 1234 ... LastLast
Results 16 to 30 of 68
Thread: T, 2T, 2T-B, 2T-C & 2T-G Specifications & Diagrams
    Default Re: T, 2T, 2T-B, 2T-C and 2T-G Specifications
    Anyway, onto the pics.....
    T, 2T, 2T-B & 2T-G Partial Engine Assembly
    T, 2T, 2T-B & 2T-G Short Block Assembly
    T, 2T, 2T-B & 2T-G Gaskets
    T, 2T, 2T-B & 2T-G Cylinder Head & Cover
    T, 2T, 2T-B & 2T-G Cylinder Block & Oil Pan
    T, 2T-B Timing Cover & Rear End Plate
    2TG Timing Cover & Rear End Plate
    seeyuzz
    river
    T, 2T, 2T-B & 2T-G Crankshaft & Pistons
    T, 2T, 2T-B Camshaft & Valves
    2T-G Camshaft & Valves
    T, 2T, 2T-B Timing Chain & Damper
    2T-G Timing Chain & Damper
    T, 2T, 2T-B & 2T-G Oil Pump
    T, 2T, 2T-B & 2T-G Oil Filter
    T, 2T, 2T-B Water Pump
    2T-G Water Pump
    ... but wait, there's more....
    seeyuzz
    river
    T, 2T & 2T-B Radiator & Water Outlet
    2T-G Radiator & Water Outlet
    T & 2T Manifold
    2T-B Manifold
    2T-G Manifold
    T, 2T, 2T-B & 2T-G Exhaust Pipe & Muffler
    T & 2T Air Cleaner (no hot air)
    T & 2T Air Cleaner (with hot air)
    2T-B Air Cleaner
    2T-G Air Cleaner
    ... more on the way..
    seeyuzz
    river
    T, 2T & 2T-B Vent Tube & Hose
    2T-G Vent Tube & Hose
    T & 2T Air Pollution
    2T-B Air Pollution
    T, 2T, 2T-B & 2T-G Ignition & Battery
    T, 2T, 2T-B & 2T-G Distributor
    ... one more post to come...
    seeyuzz
    river
    T & 2T Fuel Pipe & Clamp
    2T-B Fuel Pipe & Clamp
    2T-G Fuel Pipe & Clamp
    T & 2T Carburetor
    2T-B Carburetor
    2T-G Carburetor
    T, 2T, 2T-B & 2T-G Fuel Pump
    Hope you enjoy them.
    seeyuzz
    river
    River - this is good info and nice work!
    Thanks sunshine. I've tried a few times to get it into the FAQ.
    seeyuzz
    river
    River, keep trying, this should definately be a FAQ!! Its pretty much half a manual!
    Got a Q for you, my Toyota "T Series Engine Repair Manual" doesnt tell me what the oil pressure is supposed to be for a 2T-G.... does yours?
    Toyota Car Club (Qld)
    Yes little lady, my manual tells me everything!!!!
    Oil temp should be 100 degrees Cels
    Oil specification should be SAE No.30
    Oil pressure @ idle speed should be more than 0.8kg/cm2 (1.1 psi)
    Oil pressure @ 2000rpm should be 3.5 - 4.6kg/cm2 (49.8 - 64.0 psi)
    Oil pressure @ 5000rpm should be 4.0 - 5.0kg/cm2 (56.9 - 71.1psi)
    I have other info, regarding releif valve tension pump type, etc. So, if you want that I can post it also.
    Hope this helps.
    seeyuzz
    river
    Thanks river!! You're the best!!
    I tested it last night at 3000rpm and got just over 50psi, so I should be in tolerence, but I will re-check it tonight now that I have the tolerance for idle pressure - this is the one that may be of concern.
    Thumbs up Re: T, 2T, 2T-B, 2T-C and 2T-G Specifications
    I reckon it should be in the FAQ too - here's my vote
    Great work River.
    is certainly not a Automotive Encyclopaedia suss_slide's Avatar
    S.A.
    sorry i didnt read all of the info but from what i did read, i couldnt find anythting about how many valves the 2tg has, does anyone know?
    Now targeting, people who are now targeting!!
    1 x exhaust and 1x intake per cylinder
    S.A.
    soooo....thast 8 valve yeah?
    yep! stupid 10 characters!!
  1. Complete 18R & 18R-G Diagrams
    By river in forum FAQ
    Last Post: 11-07-2006, 08:23 AM
  2. T, 2T, 2T-B & 2T-G Engine Diagrams - Mods Please Delete
    Last Post: 03-05-2006, 07:12 PM
