Anyway, onto the pics.....
T, 2T, 2T-B & 2T-G Partial Engine Assembly
T, 2T, 2T-B & 2T-G Short Block Assembly
T, 2T, 2T-B & 2T-G Gaskets
T, 2T, 2T-B & 2T-G Cylinder Head & Cover
T, 2T, 2T-B & 2T-G Cylinder Block & Oil Pan
T, 2T-B Timing Cover & Rear End Plate
2TG Timing Cover & Rear End Plate
seeyuzz
river
River - this is good info and nice work!
Thanks sunshine. I've tried a few times to get it into the FAQ.![]()
seeyuzz
river
River, keep trying, this should definately be a FAQ!! Its pretty much half a manual!
Got a Q for you, my Toyota "T Series Engine Repair Manual" doesnt tell me what the oil pressure is supposed to be for a 2T-G....does yours?
Toyota Car Club (Qld)
Yes little lady, my manual tells me everything!!!!
Oil temp should be 100 degrees Cels
Oil specification should be SAE No.30
Oil pressure @ idle speed should be more than 0.8kg/cm2 (1.1 psi)
Oil pressure @ 2000rpm should be 3.5 - 4.6kg/cm2 (49.8 - 64.0 psi)
Oil pressure @ 5000rpm should be 4.0 - 5.0kg/cm2 (56.9 - 71.1psi)
I have other info, regarding releif valve tension pump type, etc. So, if you want that I can post it also.
Hope this helps.
seeyuzz
river
Thanks river!! You're the best!!
I tested it last night at 3000rpm and got just over 50psi, so I should be in tolerence, but I will re-check it tonight now that I have the tolerance for idle pressure - this is the one that may be of concern.
I reckon it should be in the FAQ too - here's my vote![]()
Great work River.
sorry i didnt read all of the info but from what i did read, i couldnt find anythting about how many valves the 2tg has, does anyone know?
Now targeting, people who are now targeting!!
1 x exhaust and 1x intake per cylinder
soooo....thast 8 valve yeah?
yep!stupid 10 characters!!
