have you tried searching the US forums? they like there engine swaps over there.
www.customtacos.com
Although, talking to a lot of wreckers when i was looking around, it is a popular conversion, and apparently easy, but they were not forthcoming about the information.
The information i can tell you though:
Gearbox's are interchangeable with the swap of the extension housing, and the bellhousing.
The engine should pretty much bolt in, you might need to swap around engine mounts, or grind the old ones off and weld the new ones in.
Everything is going to be custom there after. Your going to need a lift pump and pressure pump with surge tank for the carby designed fuel tank. Going to need custom wiring. You can use the same radiator with custom radiator hoses...
Everything is going to be custom there after. Best i can help you with though.
