Page 3 of 3 FirstFirst 123
Results 31 to 33 of 33
Thread: 1997 Hilux 22r to 3rz -fe
    Aug 2006
    Default Re: 1997 Hilux 22r to 3rz -fe
    where can i get one for under 2.5k???
    Jan 2008
    queensland
    thread dig
    how much difference in l diesel mounts and 3rz mounts in position on the chassis
    2009 aurion
    Purple 2000 Hilux - 1UZ
    Lexus wiring junky Grease Monkey Demon's Avatar
    Oct 2009
    South Africa
    Just make sure you get all the bits on the motor otherwise you will cry when it comes to that. Make sure you got SPD from a cluster ( you dont have SPD on your current cluster) thats if you are going standard ECU with this mod. SPD is a reading from speedo to the ECU. Get ready to put in plenty relays and stuff because your truck only has about one relay and about two fuses. Im pulling a 3rz and dropping 1jz vvti ( 3rz is heavy on fuel but it is strong)
  1. changing the gear ratio's in hilux diff.
  2. Alloy Trays on Hilux/ Cruiser/ Hilux 4 door
    By Robbos_Toyotas in forum Tech and Conversions
    Last Post: 02-03-2006, 06:54 PM
  3. hilux caliper comparisons?
    By AE25 in forum Tech and Conversions
    Last Post: 05-12-2005, 06:04 PM
