thread dig
how much difference in l diesel mounts and 3rz mounts in position on the chassis
where can i get one for under 2.5k???
thread dig
2009 aurion
Purple 2000 Hilux - 1UZ![]()
Just make sure you get all the bits on the motor otherwise you will cry when it comes to that. Make sure you got SPD from a cluster ( you dont have SPD on your current cluster) thats if you are going standard ECU with this mod. SPD is a reading from speedo to the ECU. Get ready to put in plenty relays and stuff because your truck only has about one relay and about two fuses. Im pulling a 3rz and dropping 1jz vvti ( 3rz is heavy on fuel but it is strong)
