Whats the cost on the R154 gear set?
				 OS Giken products
 OS Giken products
				Hey peeps,
Otomoto have been the Australian and New Zealand distributors for Japanese OS Giken parts for a number of years now, specialising in single and multi-plate racing clutches, cross gear sets, mechanical LSD centres, and even 1500hp-capable RB30 crate engines.
Our most exciting addition to the line up in recent times has been the release of the 'STR' twin plate clutch system. Designed for road use, the STR provides a much more user-friendly operation than conventional twin plate units, despite still being rated to handle 600 flywheel horsepower. Included in each kit is the clutch itself, an OS Giken chromemoly flywheel, and a bearing/carrier set or pull-push converter where required.
The STR is available for the following models:
SW20 - $2100
JZZ30 - $2550
JZA70 - $2550
JZX90 - $2550
JZA80 - $2550
Of course, we can also offer a huge range of other clutches, from 4AGE singles to quad-plate monsters, capable of 1200hp+.
The legendary OS Giken 'Super-Lock' LSD centre is available for most popular Toyota models, with smooth operation and superior locking available via the use of 14 plates per side as opposed to the usual 6-8 plates per side of most aftermarket centres.
Perfect for street, drift, drag, or circuit work, the Super Lock LSD can be supplied for JZA70, JZX90, JZX100, JZX110, JZA80, JZZ30, UZZ30, JZS147, JZS161/GS300, and also T-series rear ends (T-18, Jap AE86 etc).
 Re: OS Giken products
				can i get a price on a r4c to suit gtr and a price on a gearset too
				Hey mate,Originally Posted by ReQuieM
Sorry for mis-leading, but I actually had a major brain-fart when creating the above post. Unfortunately we cannot supply an aftermarket gear set for R154 boxes.
Once again, sorry for the confusion. My bad!
ae95 - Prices for the GT-R bits are as follows:
R4C quad-plate clutch to suit R34 GT-R - $3595 (includes pull-push conversion kit and is rated to around 1200hp)
3-gear cross mission set to suit R34 GT-R - $3000 (Reinforced input shaft is also available for $870)
5-gear cross mission set to suit R34 GT-R - $4275 (Includes reinforced input shaft)
				Price on a single plate clutch for JZA70..........prefer something streetable
I used to eat alot of natural foods. That was until I learned that most people died of natural causes.
				You're probably better off going for an STR twin plate. Very driver-friendly, and rated to 600hp.Originally Posted by Sir_2jza70
$2550 including pull-push converter (usually $580 seperately).
That's everything from flywheel to clutch cover, and completely rebuildable with all parts available seperately.
If you really wanted a single plate, you're looking at either $2100 with a billet aluminium cover, or $1950 with a pressed steel cover
Jeremy.
				Hey Jeremy, could you post or PM me some prices on the rebuildable parts? (especially friction discs).. just want to get an idea of maintenance costs etc
				Hey mate,Originally Posted by Draven
It depends on the clutch. Plates cost anywhere from $200 to 460 each. If you're running a JZ engine you'd be looking at the upper end of that scale too.
Complete rebuild kit prices are as follows:
Overhaul A Set (New clutch disks, centre plates, pressure plate and bolts) - approx. $1000
Overhaul B Set (New clutch disks, centre plates, pressure plate, clutch cover, bolts - approx. $1300
Jeremy.
				PM Sent re OS giken LSD for F series.
Thanks Jeremy,
Jeremy
R.I.P Peter Brock.
				PM replied Jezz...Originally Posted by Rallystanza
				hey.. how much would i be looking at for a twin or single plate for a t-50..
pm reply would be best. cheers
adrian
				Hi guys, Jeremy no longer works for Otomoto so i'll be taking care of the Otomoto threads.
Contact me at [email protected] or post a question here and i'll get back to you.
Grant
				hey grant,
just wanted to get a price on a 4age single plate clutch on a 225mm flywheel?
thanks
James
				Hi James, you will be looking at $1495.00 for a pressed steel cover single plate for 4A-GE including release bearing and carrier. The flywheel diameter is 215mm though. Do you have a OS single on a 225mm flywheel?
Cheer
Grant
				Grant,
no i do not have a 225mm flywheel but was hoping to go up to that size when i changed to a supra box,
a 215mm would probably still be suitable, is that a super single??
also is a lightened flywheel supplied with the single kits??
thanks for your reply.
James
