Hi rexeater
i have an echo as a runaround at the moment and i have done a few things that have made it alot more fun to drive, i would do them in this order and it would have only cost me 600 or so all up.
lower springs make a world of difference to this car, not too low without new dampeners otherwise you will go backwards before you go fowards.
a rear sway bar with poly bushes on the lca and front sway bar, less plow understeer quite balanced in corners but can be a handfull in the wet if you are careless.
toyota corolla 15 inch steel wheels with 195 50 15 tyres. I got some good quality second hand tyres from a japanese tyre importer. (bridgestone grid 2 or 3 cant remember)
making it faster? dont waste your money unless you absolutly have too, just get a better base for a fast car. However i have heard that the 1.5L motor will bolt in with only a computer swap for a bit more power, they can be had for 1000-1200 from importers.
hope this helps
Daniel.
