Originally Posted by
thechuckster
edit: you need ot find out if the turbo is getting oil from engine start-up, the inline restrictor will result in oil drain occuring way after it gets into the turbo. The drain might be easier, but a turbo without incoming oil is a door-stop.
you change to a cheaper brand of crack, kingmick?
-when you crank it with no spark there's still injectors running - why spread petol everywhere?
-what energy lost? the whole point of removing the plugs is to use less energy to crank the engine.
-the description that this guys is giving suggests that the new turbo is still attached to the engine, there's no need undo all the hardware (piping, dump, oil lines, coolant lines) for this simple test.
-this test will not move enough air to make the turbine rotate - thus it's not going to damage the dead turbo any further.
i'm trying to help the guy, you just can't help being an arsehole.
