Results 16 to 30 of 31
Thread: 4agte Info
    dirty little Grease Monkey Cam-Rush's Avatar
    victoria
    Default Re: 4agte Info
    Shit yeah! ramp up the rep brother!
    Signatures must be no more than 5 lines of text at 1024x768. Advertising is not allowed in signatures.
    Thanx heaps for the rep guys.
    Thanks, very useful. +rep
    S.A
    Great info for the newbies and some for the masters
    +rep for puttin it out there !
    vic
    ok i was searching for info on what turbo would suit my needs and engine/hp goals and i have found it hard to make sense of a lot of the info thats out there...
    i've searched heaps of different turbo info websites and sales pages which give you a whole bunch of numbers that deal with trim, and A/R's and so on...
    i wont pretend to understand what difference a different trim on the exhaust wheel will make, so im after some basic advice on what turbo you know will work and give me what i want...
    i currently have a built 4age with 8.4:1 compression ratio forged arias pistons, standard bigport gze cams, bigport head, 7 rib block, fully balanced bottom end and reconditioned head, 440cc injectors, microtech and a s14 silvia T28 turbo running 15psi... it made 199hp on the last tune at SAS...
    my hp goal is closer to 220-240 depending on how much boost i would need to run...
    my current setup is quite laggy and 15 psi is not generated untill close to 5000rpm... the hit in boost response between 4000 and 5000rpm is quite harsh... at anything under 4000 im lucky to see 5psi in any gear..
    im not saying that is a bad thing... but i would like to see some more usefull boost below 4000rpm...
    im after a new generation ball bearing turbo that will spool up much quicker and still provide me with enough efficiency and flow to get to my power goal... at this point in time i should mention that i would like to limit boost to 20psi max...
    is this possible??? can i get that sort of high rpm power and still have a driveable and usefull boost curve?
    any info would be greatly appreciated..
    p.s... sorry for the noob question LOL...
    AE92 4AGTE SX HATCH---- 14.2 @ 99 MPH
    Junior Member Backyard Mechanic cri_ag's Avatar
    i have 250hp on 17psi using a gt2871r, makes full boost well before 5grand! turbo is maybe a tiny bit to big but maybe gt2860rs (disco potato) would be perfect? dunno, given the choice id definatly go the gt2871r again but.
    Feb 2007
    Timaru
    I have 280hp atw @ 17psi.
    Silvertop 20V head with std cams.
    The turbo I use started off as a silvia non-bb turbo,
    and has had the larger GTiR exh wheel fitted and a larger wheel on the front too.
    Compression ratio makes a huge difference to lag.
    When i changed fro 8:1 to 9:1 I got same boost 1500rpm earlier,
    which is now about 3800.
    - KE70 Corolla Dx -
    - 500hp+ 7AGTE 20V turbo -
    - MRS/Hayabusa turbo **sold**
    vic
    thanks for the replies guys...
    i've pretty much bought a GT2535 so ill post up how it goes...
    just on a second note... whats all you 4AGTE guys fuel economy like?
    what ECU and what tuner?
    mines terrible!
    Offset is king Grease Monkey monkeymajik's Avatar
    GZE ecu with a td05h-16g.
    It's as economical as you drive it. Best I've done was approx 400km on approx 30L. That was all highway though. Worst was a whole tank in one trackday.
    monkeymajik
    "Recommended for those who prefer
    hot driving action and big angle drift."
    JDM Style Tuning - Super Late Braking Technique!
    Feb 2007
    Timaru
    Fuel economy? What's that, lol.
    My car is race only so will be bad, but 2.4km circuit and about 1L per lap of fuel and 180ml of water injection.
    - KE70 Corolla Dx -
    Quote Originally Posted by NVD05X
    mines terrible!
    gze ECU. bout 400k's max in hi-way and about 270 - 300 round town. as mentioned above, all depends how much the loud pedal is pushed in, and how often too i spose. no more un economical than the gze was really.
    mines same, hammer it on 17psi and watch the gauge move! (not quite that bad, but close) i was getting 440+km from a tank(40L) on the highway (before boost was wound up) . my computer is haltech e6k and tuned by Brett form DRC (very happy with brett's tunning so far, id deffinatly reccomend going to see him)
    vic
    who's DRC?!
    i get 260k's to a tank of granny driving...
    dynamic racing concepts, they are at greenacre. workshop is fairly new. just make sure you speak to brett.
    NVD05X: what sort of dump pipe do you have there? I bet I would able to help gain boost quicker with a redesign as there are so very few proper pipes out there
    DX20VT: what pistons are you using, sorry if you mentioned it earlier
  1. 4agte suzuki sierra!
    By 4agtezook in forum Tech and Conversions
    Last Post: 07-02-2007, 10:48 AM
  2. 2JZ-gte - interference details and random vvti info
    By Draven in forum Tech and Conversions
    Last Post: 18-06-2006, 07:06 PM
  3. 4AGZE to 4AGTE in AE86 Info needed
    Last Post: 17-06-2006, 11:15 AM
