Results 16 to 27 of 27
Thread: easy way to strip paint from entire caliper assembly?
    User Conversion King
    NWA
    Default Re: easy way to strip paint from entire caliper assembly?
    most engine rebuilders and some engineering workshops have an acid bath. the same one they use to clean cylinder heads etc.
    take it to them, offer some cash ....then go back a couple days later.
    the paint will have fallen off and there will be a spotless surface ready for a quick solvent clean, then a paint.
    no health hazards to you either
    hello
    Hoppers Crossing
    i'd go with what brett says...if its convenient..
    would I be correct in assuming that VHT caliper paint is as good as the rest of their products?
    Anyone have some pics of the colour of their "gold" colour?
    Quote Originally Posted by Draven
    I have found it to be great, mine still looks like the day it was painted after 2 years on the front calipers.
    I haven't had any experience with anything other than their black caliper paint though - I have never had the inclination to draw attention to my single piston calipers
    My KE25 thread
    Pull the calipers apart, use paint stripper but don't let it sit on there longer than needed. Use gloves and a mask and rub them clean with some steel wool. Clean them off and rub over with surface prep stuff (i.e. Prepsol).
    Procure can of VHT brake caliper paint and paint. Mine look just like the day I did them over a year ago. Follow the directions to the T and you will come up with the same result.
    Purchase a rebuild kit and give the calipers some new seals. Put brake calipers on and enjoy the fact they look good and are mechanically perfect.
    Quote Originally Posted by JustCallMeFrank
    I think this step is being omitted? Hence the worry about strippers and cleanser destroying seals etc. Is that the case Draven?
    My KE25 thread
    Junior Member Chief Engine Builder Classique71's Avatar
    just take them off - take them apart - get them cleaned right + powdercoated , rebuild , and have bling ..
    Worked sweet for my St205 calipers , and you know that shite isnt gunna wear off in a hurry ..
    ( in short - spend up and dont be a cheap ass )
    do it once do it right !
    Saphira - ST205 Celica GT-FOUR Group A NZ No:1/4
    "Mongrel Garage - back on Aussie soil! "
    no, I'm rebuilding them with new seals, and since the pads have been painted new pads too (pity, they were like 90%)
    Cool. Painting pads - nice!
    My KE25 thread
    painting pads red - thats GOTTA make them race ones
    Oh I read it that way too, but I was just inferring he should do it anyway
    paintstripper is probably bad for the rubber seals,
    i say soak them in brakefluid overnight and the next day wash them off, and the seals wont be harmed at all
    blake
  1. Guide: Removing paint from plastic parts (more input needed)
    Last Post: 13-04-2006, 01:09 PM
  2. putting a spacer in a caliper to allow a thicker disc. wise?
    Last Post: 13-03-2006, 02:40 PM
